Which are the correct or best oins in an ESP32-S3 Devkit C1 to conect Can H and Can L ?
As you can see, I'm a complete beginer. Pls, excuse my poor english.
Regards.
CAN BUS with ESP32-S3
Re: CAN BUS with ESP32-S3
I am not sure but this one may help you: https://www.cnx-software.com/2023/05/12 ... ver%20chip.
You don't connect CAN-H or CAN-L to the ESP; an external transceiver chip (e.g. a TJA1051) is needed to translate between RX/TX on the ESP and the CAN bus, see e.g. https://docs.espressif.com/projects/esp ... ransceiver or https://www.circuitstate.com/tutorials/ ... d-arduino/
Thanks to both.
I have several Tja1051 because I want to connect 6 Esp32 ( 1 S3 and 5 S) . I'm programing with Arduino IDE + CAN library . Is there adequate GPIO for TX and RX coming from the module Tja1051 ?.
UART1_TXD and UART1_RXD are godd for this function?
Regards
Regards
Users browsing this forum: No registered users and 192 guests
