Adafruit library for MCP23017 is Not working using new Arduino Nano ESP32 development board (Arduino IDE).
Arduino Nano ESP32 development board is using ESP32-S3 MCU.
When compiling using ESP32-S3 board, there was no error but when using new Arduino Nano ESP32 board, there were errors.
Can somebody please update the library? Thank you in advance for your help.
Adafruit library for MCP23017 is Not working when using new Arduino Nano ESP32 development board (Arduino IDE).
Re: Adafruit library for MCP23017 is Not working when using new Arduino Nano ESP32 development board (Arduino IDE).
I hope ESP team will consider this issue seriously.
Thank you!
Here are the compilation results using ESP32 S3 Dev Module and Arduino nano ESP32 as board. I used the example code Adafruit MCP23017 Arduino Library (mcp23xxx)blink).
ESP32 S3 Dev Module as board: (compilation OK)
Sketch uses 287321 bytes (21%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20304 bytes (6%) of dynamic memory, leaving 307376 bytes for local variables. Maximum is 327680 bytes.
Arduino nano ESP32 as board:
Thank you!
In file included from C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/Arduino.h:223,
from C:\Users\chris\AppData\Local\Temp\arduino_build_162304\sketch\mcp23xxx_blink.ino.cpp:1:
C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:47:61: error: 'digitalPinToGPIONumber' is not a type
#define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode)
C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library\src/Adafruit_MCP23XXX.h:50:8: note: in expansion of macro 'pinMode'
void pinMode(uint8_t pin, uint8_t mode);
C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:42:65: error: 'digitalPinToGPIONumber' is not a type
#define digitalRead(pin) digitalRead(digitalPinToGPIONumber(pin))
C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library\src/Adafruit_MCP23XXX.h:51:11: note: in expansion of macro 'digitalRead'
uint8_t digitalRead(uint8_t pin);
C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:46:66: error: 'digitalPinToGPIONumber' is not a type
#define digitalWrite(pin, val) digitalWrite(digitalPinToGPIONumber(pin), val)
C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library\src/Adafruit_MCP23XXX.h:52:8: note: in expansion of macro 'digitalWrite'
void digitalWrite(uint8_t pin, uint8_t value);
C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library\examples\mcp23xxx_blink\mcp23xxx_blink.ino: In function 'void setup()':
C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:47:83: error: invalid conversion from 'int8_t' {aka 'signed char'} to 'int ()(uint8_t)' {aka 'int ()(unsigned char)'} [-fpermissive]
C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library\examples\mcp23xxx_blink\mcp23xxx_blink.ino:30:7: note: in expansion of macro 'pinMode'
mcp.pinMode(LED_PIN, OUTPUT);
C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:47:61: note: initializing argument 1 of 'void Adafruit_MCP23XXX::pinMode(int (*)(uint8_t), uint8_t)'
C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library\examples\mcp23xxx_blink\mcp23xxx_blink.ino: In function 'void loop()':
C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:46:88: error: invalid conversion from 'int8_t' {aka 'signed char'} to 'int ()(uint8_t)' {aka 'int ()(unsigned char)'} [-fpermissive]
C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library\examples\mcp23xxx_blink\mcp23xxx_blink.ino:36:7: note: in expansion of macro 'digitalWrite'
mcp.digitalWrite(LED_PIN, HIGH);
C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:46:66: note: initializing argument 1 of 'void Adafruit_MCP23XXX::digitalWrite(int (*)(uint8_t), uint8_t)'
C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library\examples\mcp23xxx_blink\mcp23xxx_blink.ino:38:7: note: in expansion of macro 'digitalWrite'
mcp.digitalWrite(LED_PIN, LOW);
Using library Adafruit_MCP23017_Arduino_Library at version 2.3.2 in folder: C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library
Using library Adafruit_BusIO at version 1.14.1 in folder: C:\Users\chris\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 2.0.0 in folder: C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\libraries\Wire
Using library SPI at version 2.0.0 in folder: C:\Users\chris\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\libraries\SPI
exit status 1
Error compiling for board Arduino Nano ESP32.
Thank you!
exit status 1
I tried the IDE Tools option "Pin numbering: By GPIO number (legacy)" and the compilation was OK!
I will try if the example code will work when i upload it to the new Arduino Nano ESP32 code.
Thank you!
Thank you!
Just curious, why would ESP team try to fix something that Adafruit wrote?I hope ESP team will consider this issue seriously.
Users browsing this forum: Google [Bot] and 155 guests
