ESP32 RMT - rmt_fill_tx_items() does not work
nocsspecop123
Postby nocsspecop123 » Thu Mar 07, 2024 8:17 am
Hello all,
I am trying to use the RMT peripheral of the ESP32 with a very simple example to send a signal-sequence in infinite loop.
If I use rmt_write_items() to activate the RMT peripheral everything works fine.
But I need to change the signal-sequence at run-time. According to the ESP32 RMT documentation, rmt_fill_tx_items() should be used to change the signal-sequence at runtime. But once I use rmt_fill_tx_items() (instead of rmt_write_items()), the RMT peripheral does not work anymore and sends just random stuff.
Here is my code:
#include <Arduino.h>
#include "driver/rmt.h"
rmt_config_t config;
rmt_item32_t items[1];
void setup()
  config.rmt_mode = RMT_MODE_TX;
  config.channel = RMT_CHANNEL_0;
  config.gpio_num = GPIO_NUM_4;
  config.mem_block_num = 1;
  config.tx_config.loop_en = 1;
  config.tx_config.carrier_en = 0;
  config.tx_config.idle_output_en = 1;
  config.tx_config.idle_level = RMT_IDLE_LEVEL_LOW;
  config.tx_config.carrier_level = RMT_CARRIER_LEVEL_HIGH;
  config.clk_div = 80; // 80MHx / 80 = 1MHz 0r 1uS per count
  ESP_ERROR_CHECK(rmt_config(&config));
  ESP_ERROR_CHECK(rmt_driver_install(config.channel, 0, 0));
  items[0].duration0 = 3;
  items[0].level0 = 1;
  items[0].duration1 = 10;
  items[0].level1 = 0;
  items[1].duration0 = 5;
  items[1].level0 = 1;
  items[1].duration1 = 5;
  items[1].level1 = 0;
  ESP_ERROR_CHECK(rmt_fill_tx_items(config.channel, items, 2, 0));
  ESP_ERROR_CHECK(rmt_tx_start(config.channel, false));
void loop()
I really would appreciate any help! I have tried a lot of code-variants and searched in the internet but it seems that rmt_fill_tx_items() is rarely used. I couldn't find any examples.
Thank you very much!
nocsspecop123
Re: ESP32 RMT - rmt_fill_tx_items() does not work
Postby nocsspecop123 » Thu Mar 07, 2024 1:32 pm
Hello all,
it seems I found the problem related to the use of rmt_fill_tx_items():
the rtm_items array that is passed to the rmt_fill_tx_items() functions seems to need the last element of the array to be set to 0 (duration0 and duration1) so that it is recognized as some sort of "end-marker". With such last element set to 0, the RMT module works in the loop as expected.
Unfortunately now I have a new issue: the period of the generated signal is much higher than expected.
I set the RMT-clock divisor to 1. When setting duration0 and duration1 to 1 tick respectively and level0 to 1 and level1 to 0 I expected a square wave with frequency of 40Mhz and period of 25ns. Instead I got a signal with a frequency of 500kHz (period of 2us):
This is the code I used:
#include <driver/rmt.h>
#define PACKET_LENGTH 	18
#define PAUSE			50
rmt_item32_t rmt_items[PACKET_LENGTH];
void setup()
    config.clk_div = 1;
    for (int i = 0; i < PACKET_LENGTH-2; i++, val <<= 1)
        rmt_items[i].duration0 = 1;
        rmt_items[i].level0 = 0;
        rmt_items[i].duration1 = 1;
        rmt_items[i].level1 = 1;
    // pause
    rmt_items[16].duration0 = PAUSE;
    rmt_items[16].level0 = 1;
    rmt_items[16].duration1 = 0;
    rmt_items[16].level1 = 0;
    // zero
    rmt_items[17].duration0 = 0;
    rmt_items[17].level0 = 0;
    rmt_items[17].duration1 = 0;
    rmt_items[17].level1 = 0;
    rmt_fill_tx_items(RMT_CHANNEL_0, rmt_items, sizeof(rmt_items)/sizeof(rmt_items[0]), 0);
    rmt_tx_start(RMT_CHANNEL_0, true);
Any idea why the frequency of the square-wave is so low?
ESP_Sprite
Postby ESP_Sprite » Fri Mar 08, 2024 4:02 am
First of all, try zero-initializing your stack-allocated variables, otherwise they may have garbage in them:
rmt_config_t config={};
nocsspecop123
Postby nocsspecop123 » Mon Mar 11, 2024 1:47 pm
Zeroeing the rmt_config_t structure did the trick, thank you!
Users browsing this forum: No registered users and 195 guests
