Flash write speed
kostyan5
Flash write speed
Postby kostyan5 » Mon Apr 09, 2018 7:46 pm
We recently switched the SPI flash chip on our product. We went from Winbond (W25Q32JV) to Macronix (MX25R3235F). For some reason flash write speeds decreased by a factor of 3. This includes both flashing and formatting SPIFFS speeds. With winbond we were able to flash fw or format spiffs in roughly 8 seconds each. After moving to Macronix, flashing and formatting takes roughly 25 seconds each.
No paramers or fw has changed. I see these timing differences when simply swapping the two versions of our device and programming using the same command. Command from programming and specs for both flash chips are below:
python2 esptool.py --chip esp32 --port /dev/tty.usbserial-DN02PNCC --baud 1500000 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 bootloader.bin 0x10000 firmware.bin 0x8000 partitions.bin
Winbond: http://www.winbond.com/resource-files/w ... 112017.pdf
Macronix: http://www.macronix.com/Lists/Datasheet ... 20v1.5.pdf
Aside from baud rate, flash freq, and dio/qio setting (which are identical in both cases), what else could effect the write speed of flash?
Thanks,
Konstantin
kostyan5
Re: Flash write speed
Postby kostyan5 » Mon Apr 09, 2018 9:11 pm
After further digging, it turns out that that particular Macronix part defaults to Ultra Low Power mode which reduces speeds. This almost certainly explains what I'm experiencing.
Users browsing this forum: No registered users and 52 guests
