Page 1 of 4
[Tool Release] FLASH_DOWNLOAD_TOOL
Posted: Fri Dec 18, 2015 6:06 am
by ESP_Faye
Here is the Flash Download Tool.
Enjoy !
Update version 1.2 and source code. ;) ;)
Release Note 160104:
exe tool:
1. fix result check function for ESP32
2. fix download error if address exceed 2Mbyes
esptool_ESP32.py is in ESP32_RTOS_SDK/tools
ESP32_FLASH_DOWNLOAD_TOOL_V1.2.0.zip
(18.73 MiB) Downloaded 6171 times
Re: [Tool Release] FLASH_DOWNLOAD_TOOL
Posted: Thu Dec 24, 2015 4:44 am
by captain_morgan
Is there or will there be an official flash tool for Linux?
Posted: Thu Dec 24, 2015 8:53 am
by scargill
Ok, got Windows all set up with an example "hello world" - compiles just great... not the foggiest idea what to do with the pins on the demo board. On the ESP8266 we have to attach 3v3 to 3v3, gnd to gnd, serial in and out - and ground GPIO0 temporarily to program..
So what is the equivalent on the demo board (the kit we received with the ESP32 board and 0.1" spacing base board. Which pins on that board need to go where??? Has anyone already programmed the chip - simple hardware guide would be great...
Posted: Thu Dec 24, 2015 12:11 pm
by NevynSelby
scargill wrote:Ok, got Windows all set up with an example "hello world" - compiles just great... not the foggiest idea what to do with the pins on the demo board. On the ESP8266 we have to attach 3v3 to 3v3, gnd to gnd, serial in and out - and ground GPIO0 temporarily to program..
Adafruit have a video looking at the tool chain and hardware set up on YouTube:
https://www.youtube.com/watch?v=HCGHb0OVz1s
regards,
Mark
Posted: Thu Dec 24, 2015 11:46 pm
by captain_morgan
It's the same as before. I've put my notes up here. https://gist.github.com/morganrallen/09 ... 9c2a621d50
Posted: Sat Jul 02, 2016 3:18 pm
by rudi ;-)
ESP Flash Tool 1.2.0 now released
a newer release of ESP32 ESP Flash Tool ( 2016-06-15 ) is online on new Resource Web Side at espressif web.
ESP32 Flash Download Tool V1.2.0
more info here
[Tool Release] v3.4.2 Flash Download Tools (ESP8266 & ESP32)
Posted: Fri Sep 30, 2016 4:45 pm
by rudi ;-)
hi guys
New Flash Download Tools V3.4.2 (ESP8266 & ESP32) released on 22 Sept 2016.
Note: windows user only
espressif support resource
[Tool Release] v3.4.4 Flash Download Tools (ESP8266 & ESP32)
Posted: Wed Nov 16, 2016 2:55 pm
by rudi ;-)
hi guys
New Flash Download Tools V3.4.4 (ESP8266 & ESP32) released on 14. Nov 2016
Posted: Thu Feb 09, 2017 2:34 pm
by Ritesh
We are normally using ESP Download Tool 3.4.2 usually in windows to flash firmware images into ESP32 based boards.
But, sometimes we are getting packet header type of error while flashing firmware same way as normally working. And also sometimes not able to flash firmware into few boards though it can be programmed using make flash command.
Also, we are generally using 912600 baudrate for that.
Does this issue has been fixed into 3.4.4 download tool or has anyone faced this type of issue while flashing firmware into higher baudrate?
Posted: Thu Feb 09, 2017 9:42 pm
by rudi ;-)
Ritesh wrote: ..
do you mean 912600 or 921600?
