does there have example have same part of component, only example's component not idf/component' s component.
please publish a more complex example include example's component folder, that we can follow it design style for own projects.
Re: does there have example have same part of component, only example's component not idf/component' s component.
Howdy wziy520,
... and following on from ESP_iggr, if you run int troubles or have questions, please don't hesitate to post back here.
I personally found the following document very good to help me understand:
http://esp-idf.readthedocs.io/en/latest ... ystem.html
If after having read that and you still have questions, don't hesitate to post back what you tried and what didn't work.
