Setting UART Pins Issue
mpulis
Postby mpulis » Tue Jul 24, 2018 12:20 pm
Hi all,
I'm trying to initialize GPIOs 13 and 9 as RX and TX pins respectively for UART 1. This is resulting in an Illegal Instruction followed by device reboot for some reason.
My code for setting up the UART driver is as follows.
gpio_set_direction(RXD1, GPIO_MODE_INPUT_OUTPUT);
gpio_set_direction(TXD1, GPIO_MODE_INPUT_OUTPUT);
xUartSendQueue = xQueueCreate(QUEUE_SIZE, sizeof(uint8_t));
xUartReceiveQueue = xQueueCreate(QUEUE_SIZE, sizeof(uint8_t));
if(xUartReceiveQueue == NULL)
	ESP_LOGE(TAG, "networkTCPServe: Failed to create receive Queue");
uart_config_t uart_config =
		.baud_rate = atoi(baudrate),
		.parity = atoi(paritybits),
		.stop_bits = atoi(stopbits),
		.flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
		.rx_flow_ctrl_thresh = 122,
uart_param_config(UARTNUM, &uart_config);
uart_set_pin(UARTNUM, TXD1, RXD1,UART_PIN_NO_CHANGE ,UART_PIN_NO_CHANGE);
ESP_LOGE(TAG, "serialInit: Serial connection initialized");
if (uart_driver_install(UARTNUM, QUEUE_SIZE * 2, QUEUE_SIZE * 2, 10, &UARTqueue, 0) == ESP_OK)
	ESP_LOGI(TAG, "serialInit: Driver install complete");
I've attached an image capture of my logging screen as well. I have already previously set up GPIOs 4 and 36 as RX and TX pins for UART1 without any problems, but I needed to change the pins for a new board configuration.
WiFive
Re: Setting UART Pins Issue
Postby WiFive » Tue Jul 24, 2018 3:17 pm
Note that GPIO6-11 are usually used for SPI flash.
https://docs.espressif.com/projects/esp ... /gpio.html
Users browsing this forum: runeruiter and 102 guests
