Component Makefiles - Adding source directories
mikemoy
Postby mikemoy » Wed Sep 26, 2018 2:59 pm
I created a test.txt file and included it in my root directory.
In component.mk i have:
COMPONENT_EMBED_FILES := test.txt
This compiles fine with no issues. I want to put my files in a subdirectory. accoding to the docs, i need to add "COMPONENT_SRCDIRS.
https://docs.espressif.com/projects/esp ... irectories
I created a new directory in root named "WebSiteFiles" and placed the files in there.
the component.mk now looks like this.
COMPONENT_SRCDIRS := WebsiteFiles
When I compile now, I get:
make[1]: *** No rule to make target '/home/Mike/esp/Projects/spiffs/main/test.txt', needed by 'embed_bin/test.txt'. Stop.
Any ideas why?
ESP_Angus
Re: Component Makefiles - Adding source directories
Postby ESP_Angus » Thu Sep 27, 2018 12:50 am
"Source directories" are checked for "source files" (.c, .cpp, .S). Try the following:
COMPONENT_EMBED_FILES := WebsiteFiles/test.txt
Paths are expanded relative to the component directory.
mikemoy
Postby mikemoy » Thu Sep 27, 2018 1:56 am
Thank you sir, that worked!
Users browsing this forum: Baidu [Spider], Google [Bot] and 118 guests
