M5stack undefined reference to `TwoWire::onReceive(void (*)(int))'
soujiro0725
Postby soujiro0725 » Mon Oct 08, 2018 3:18 am
Arduino ide 1.8.7
Hi. I am trying to establish i2c communication with M5stack.
But the following code raises an error.
#include <Wire.h>
#include <M5Stack.h>
int SLAVE_ADDRESS = 0x40;
  M5.begin();
  Wire.begin(SLAVE_ADDRESS);    //set slave address
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);
  if (m5.BtnA.wasPressed()) {
    M5.Lcd.printf("hello");
    M5.Lcd.printf("");
  M5.update();
  delay(100);
void receiveEvent(int howMany) {
The error is
Arduino:1.8.7 (Mac OS X), ボード:"M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
sketch/sketch_oct04a.ino.cpp.o:(.literal._Z5setupv+0x1c): undefined reference to `TwoWire::onReceive(void (*)(int))'
sketch/sketch_oct04a.ino.cpp.o: In function `setup()':
/Users/soichi/Documents/Arduino/sketch_oct04a/sketch_oct04a.ino:33: undefined reference to `TwoWire::onReceive(void (*)(int))'
collect2: error: ld returned 1 exit status
Without "onReceive" method call, it gets compiled fine.
The code seems to have found the library, Wire.h, but "onReceive" method is the problem.
Does anyone guess why?
Users browsing this forum: Majestic-12 [Bot], ok-home and 126 guests
