Unable to program ESP32-SOLO-1 using JTAG
ajaykk
Postby ajaykk » Thu Oct 11, 2018 6:35 am
I am trying to program a bare esp32-solo-1 module through JTAG. I am using ESP-WROVER-KIT v3 for JTAG programming but could not program, getting this message:-
$~/esp/openocd-esp32/bin/openocd -s ~/esp/openocd-esp32/share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg -c "program_esp32 build/app-template.bin 0x10000 verify exit"
Open On-Chip Debugger 0.10.0-dev (2018-09-20-12:52)Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : JTAG tap: esp32.cpu1 tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Warn : JTAG tap: esp32.cpu1       UNEXPECTED: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Error: JTAG tap: esp32.cpu1  expected 1 of 1: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Error: esp32.cpu1: IR capture error; saw 0x1f not 0x01
cpu0: Current bits set: none
cpu1: Current bits set: BreakIn
Error: timed out while waiting for target halted / 1 - 2
also I tried enabling single core mode in menuconfig and uncommenting set ESP32_ONLYCPU 1 in esp-wroom-32.cfg, but nothing changed.
BTW I am able to flash program through serial bootloader.
Return to “General Discussion”
Users browsing this forum: ecc esp and 31 guests
