About FreeRTOS and Project
Is FreeRTOS and Application developed in the same project? Can I separate building and flashing in my project? Looking forward to your answer, Thank you!
Re: About FreeRTOS and Project
FreeRTOS is part of ESP-IDF; if you build your project you will also compile the FreeRTOS files.
Thanks you very much!ESP_Sprite wrote:FreeRTOS is part of ESP-IDF; if you build your project you will also compile the FreeRTOS files.
Users browsing this forum: Bing [Bot] and 91 guests
