Does putting the ESP32 into deep sleep "reset" the heap allocations? I basically scan for BLE devices every 5s or so, then if there's nothing to do I put it into deep sleep for X seconds.
I was either going to use vectors for performing work, or statically allocated buffers depending on if I should be concerned about heap fragmentation. I'm fairly new to MCU programming. Thanks!
Heap Fragmentation and Deep Sleep
Re: Heap Fragmentation and Deep Sleep
Coming out of deep sleep is basically like a cold boot with a few exceptions like rtc ram and wake stub. But if you want your app to resume you have to use light sleep.
That, or manually save whatever you need to save to RTC RAM.
Does setting the option ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF reset the RTC/ULP RAM when the ESP32 is put to sleep? That way I can put a vector into RTC RAM, and when there's nothing in RTC RAM I can occasionally use the above option to re-claim the heap on the RTC as well (I'll be adding/removing items on there every so often).
No, the power domain of RTC data memory is ESP_PD_DOMAIN_RTC_SLOW_MEM.
Thank you!
Users browsing this forum: No registered users and 125 guests
