Current implementation uses CONFIG_MQTT_PROTOCOL_311 setting to decide mqtt
protocol version. However, as a mqtt client, it needs to support different
versions because we don't know which version is used (or supported) by the broker.
Would you consider to make it run-time configurable rather than decide by compile time?
esp-mqtt: mqtt protocol version should be run-time configurable
Users browsing this forum: No registered users and 221 guests
