High frequency GPIO Interrupt
dragondgold
Postby dragondgold » Sat Feb 09, 2019 5:03 am
I'm having a problem with "high-frequency" GPIO interrupt. I have a signal coming from another microcontroller that generates a 50us low pulse every 12ms and I capture this pulse using a falling-edge interrupt to send a task notification to a task with the highest priority in all my program.
The GPIO ISR service is placed in IRAM using:
gpio_install_isr_service(ESP_INTR_FLAG_IRAM);
The interrupt type is GPIO_INTR_NEGEDGE and the ISR handler looks like this:
static void IRAM_ATTR scl_isr_handler(void* arg)
    static BaseType_t xHigherPriorityTaskWoken = pdFALSE;
    if(!gpio_get_level(PIC16_PIN))
        vTaskNotifyGiveFromISR(task_handle, &xHigherPriorityTaskWoken);
        if(xHigherPriorityTaskWoken)
            portYIELD_FROM_ISR();
The problem is, this works for around 250 ms after ESP32 boot and then the interrupt stops being fired (I'm checking everything with a logic analyzer and logs). However, if I increase the time to generate a 50us low pulse every 100ms instead of 12ms, it works as expected. How can I diagnose this problem? Can't the ESP32 handle an interrupt every 12ms? Even the RTOS tick rate is faster than that.
Re: High frequency GPIO Interrupt
Postby ESP_Sprite » Sat Feb 09, 2019 10:32 am
It should indeed have no issue handling that. What ESP-IDF version are you using? Do you happen to have the full code for this available somewhere?
dragondgold
Postby dragondgold » Sat Feb 09, 2019 5:14 pm
Hi, thank you for your response! I'm using the latest release/v3.1 branch. Here is some more code:
main.c: https://pastebin.com/iG74a6wi
power_monitor.c: https://pastebin.com/vc52Yqnj
sdkconfig: https://pastebin.com/E6C7h5GG
The ESP32 is communicating with a PIC16 microcontroller through an I2C bus. There isn't any other device on the bus so when the PIC16 has new data available it generates a 50us low pulse on the SCL line, the ESP32 detects this pulse and starts reading data. At first, I thought the I2C was hanging in the ESP32 but I can see that the problem is indeed that the interrupt is not firing because I inserted an ets_printf() in it to check.
Here is a capture from the logic analyzer:
The red circles are the pulses generated by the PIC16. As you can see the ESP32 works as expected in the beginning but after 50ms it simply stops.
Return to “General Discussion”
Users browsing this forum: Google [Bot] and 23 guests
