When I tried to hook through openocd into ESP_WROVER kit v4.1, I could n't. logs below
bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp32-wrover.cfg
Open On-Chip Debugger 0.10.0-dev (2018-11-05-04:03)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x
.. And last two lines keep repeating effectively one of the core keeps resetting I guess. (should I set off one cpu?)
Update 1:
even with set ESP32_RTOS none & set ESP32_ONLYCPU 1, same issue..
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Now, anything wrong with openocd config? any quick fix?
openocd configuration for ESP_WROVER kit
Re: openocd configuration for ESP_WROVER kit
I misunderstood the logs to be resetting, but with no issues, I can run gdb.
This is resolved.
This is resolved.
Users browsing this forum: No registered users and 115 guests
