So I have managed to add xtensa compiler/debugger to CLion, and code completion and all the basic stuff works fine. I can run the build configuration and it will compile all the code for me. But when i run 'make flash' my sdkconfig resets to blank values so each time i want to run it i need to edit it with 'make menuconfig' first?
Anyone had similar issues?
Clion configuration and make flash
Re: Clion configuration and make flash
As CLion uses CMake as build system, you should stick to it when running flash/monitor targets.
I think your issue is that you build your project with CMake and then run `make flash` which would try to build again entire project with GNU make build system.
You can use `idf.py flash` and/or `idf.py monitor` which work fine in CLion terminal.
I actually was wondering if it is possible to debug CMake files with some nice GUI tool or at least convenient way.
I'm interested to hear how - or if - you got passed the problems where CMake complains that the compiler can't compile a simple test program - that's where I got stuck when trying to use CLion. This happens on clean builds with no pre-existing CMake cache.nesicarh wrote: ↑Wed Feb 13, 2019 3:20 pmHi,
CLion works fine on linux, no tweaking required. Actually the IDE detects the default (system gcc) compiler/make/gdb under Settings->Toolchains and is happy to launch the cmake from IDF, which then finds xtensa (and runs compiler check like when executed from idf.py build).
Assuming it may work the same way on windows, IDE would detect system visual studio, then when on the actual cmake run it would set esp32 toolchain.
Hm, that's not my experience (I'm on Linux too). Perhaps they have done something recently that has fixed this.
Yeah, that was the problem. Thank you very much! As for the cmake project complaining, i just set the variables in Build settings and added idf path and path to environment variables. It worked just fine.Hi,
Users browsing this forum: Google [Bot] and 122 guests
