hello friends,
I am testing my device with my firmware.
After 3-4 Hours my device just stops with out any error.
even monitor Shows nothing.
How do I find whats reason for hanging.
device Hangs
Re: device Hangs
Any chance you can force a core dump, using e.g. a button irq or something?
Re: device Hangs
hello ESP_Sprite
I didnt get what you are saying...Kindly elobrate please !
-Thanks
-Thanks
Re: device Hangs
hello Esp_spirite,
Here is Core Dump, Kindly can u look at this
==================== CURRENT THREAD STACK =====================
#-1 0x4000bff0 in ?? ()
Backtrace stopped: Cannot access memory at address 0x4000bff0
======================== THREADS INFO =========================
Id Target Id Frame
16 process 15 xQueueGenericReceive (xQueue=0x3ffb7a5c, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-idf/comp onents/freertos/queue.c:1580
15 process 14 xQueueGenericReceive (xQueue=0x3ffcaa30, pvBuffer=0x3ff cbe60, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-i df/components/freertos/queue.c:1580
14 process 13 xQueueGenericReceive (xQueue=0x3ffb2d30, pvBuffer=0x3ff d7d70, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-i df/components/freertos/queue.c:1580
13 process 12 xQueueGenericReceive (xQueue=0x3ffb6110, pvBuffer=0x3ff d9f70, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-i df/components/freertos/queue.c:1580
12 process 11 xQueueGenericReceive (xQueue=0x3ffdbc78, pvBuffer=0x3ff dd130, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-i df/components/freertos/queue.c:1580
11 process 10 xQueueGenericReceive (xQueue=0x3ffdad60, pvBuffer=0x3ff db710, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-i df/components/freertos/queue.c:1580
10 process 9 xQueueGenericReceive (xQueue=0x3ffb5a4c, pvBuffer=0x3ff da970, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-i df/components/freertos/queue.c:1580
9 process 8 xQueueGenericReceive (xQueue=0x3ffb7eb4, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-idf/comp onents/freertos/queue.c:1580
8 process 7 xQueueGenericReceive (xQueue=0x3ffc9718, pvBuffer=0x3ff ca790, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-i df/components/freertos/queue.c:1580
7 process 6 0x40095770 in prvProcessTimerOrBlockTask (xNextExpireTi me=1073492980, xListWasEmpty=<optimized out>) at C:/msys32/home/renu/esp/esp-idf /components/freertos/timers.c:570
6 process 5 0x40093a06 in vTaskDelay (xTicksToDelay=<optimized out> ) at C:/msys32/home/renu/esp/esp-idf/components/freertos/tasks.c:1459
5 process 4 0x40093a06 in vTaskDelay (xTicksToDelay=<optimized out> ) at C:/msys32/home/renu/esp/esp-idf/components/freertos/tasks.c:1459
4 process 3 xQueueGenericReceive (xQueue=0x3ffb2f50, pvBuffer=0x0, xTicksToWait=100, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-idf/components/ freertos/queue.c:1580
3 process 2 xQueueGenericReceive (xQueue=0x3ffbd7b4, pvBuffer=0x3ff c9660, xTicksToWait=10, xJustPeeking=0) at C:/msys32/home/renu/esp/esp-idf/compo nents/freertos/queue.c:1580
2 process 1 0x40181896 in vsnprintf (str=0x0, size=1, fmt=0x8009483 a <error: Cannot access memory at address 0x8009483a>, ap=...) at ../../../.././ newlib/libc/stdio/vsnprintf.c:42
* 1 <main task> 0x4000bff0 in ?? ()
Re: device Hangs
Looks like the system is still doing its thing... can you give a bit more info about what it should be doing?
Users browsing this forum: Google [Bot] and 153 guests
