Hi to all
I'm starting to use ESP32 and make some test with some example project using the mingw32.exe enviromet and the make flash command.
All works fine but i can' rename my project folder from the example name to a new name, if i simply rename i get an error.
make[1]: *** Nessuna regola per generare l'obiettivo "D:/msys32/home/paolo.lippi/esp/scan/main/Hydros103.c", necessario per "Hydros103.o". Arresto.
make: *** [D:/msys32/home/paolo.lippi/esp/esp-idf/make/project.mk:468: component-main-build] Error 2
Have you any suggest?
Rename project folder
Re: Rename project folder
Remove the build folder; it contains dependency files which refer to your sources by absolute paths (which break if you rename the project folder.) If you build the project afterwards, it'll recreate the build folder with the correct paths.
Users browsing this forum: No registered users and 229 guests
