How to build the Codec Device Test Application
crosswick
Postby crosswick » Mon Feb 05, 2024 8:27 pm
Hi, how do I build this?
https://github.com/espressif/esp-adf/tr ... c_dev/test
running `idf.py build` in that folder gives this output:
Executing action: all (aliases: build)
Running cmake in directory /Users/steven/.espressif/esp-adf/components/esp_codec_dev/test/build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=/Users/steven/.espressif/python_env/idf5.3_py3.11_env/bin/python -DESP_PLATFORM=1 -DCCACHE_ENABLE=0 /Users/steven/.espressif/esp-adf/components/esp_codec_dev/test"...
CMake Warning (dev) in CMakeLists.txt:
  No project() command is present.  The top-level CMakeLists.txt file must
  contain a literal, direct call to the project() command.  Add a line of
  code such as
    project(ProjectName)
  near the top of the file, but after cmake_minimum_required().
  CMake is pretending there is a "project(Project)" command on the first
  line.
This warning is for project developers.  Use -Wno-dev to suppress it.
  cmake_minimum_required() should be called prior to this top-level project()
  call.  Please see the cmake-commands(7) manual for usage documentation of
  both commands.
-- The C compiler identification is AppleClang 14.0.0.14000029
-- The CXX compiler identification is AppleClang 14.0.0.14000029
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at CMakeLists.txt:1 (idf_component_register):
  Unknown CMake command "idf_component_register".
  No cmake_minimum_required command is present.  A line of code such as
    cmake_minimum_required(VERSION 3.28)
  should be added at the top of the file.  The version specified may be lower
  if you wish to support older CMake versions for this project.  For more
  information run "cmake --help-policy CMP0000".
cmake failed with exit code 1, output of the command is in the /Users/steven/.espressif/esp-adf/components/esp_codec_dev/test/build/log/idf_py_stderr_output_29116 and /Users/steven/.espressif/esp-adf/components/esp_codec_dev/test/build/log/idf_py_stdout_output_29116
crosswick
Re: How to build the Codec Device Test Application
Postby crosswick » Tue Feb 06, 2024 1:28 pm
Users browsing this forum: Google [Bot] and 77 guests
