I've spent days trying to make this work and I just can't.
It would be a huge help if you could please provide an example showing how to play a WAV file to a bluetooth speaker from SPIFFS please?
Ideally the example would play WAV files with different bit rates and different sample rates.
thanks .
Could you please provide an example of playing WAV from spiffs to bluetooth speaker?
Re: Could you please provide an example of playing WAV from spiffs to bluetooth speaker?
Can I suggest Espressif uses the following code as a start point to create an an official example in the ADF to show how this is done?
https://github.com/bootrino/esp32_spiffs_wav_bluetooth
Please note that there is still a problem in the above code which is that the beginning of the audio is not played on the bluetooth speaker, as mentioned in this thread: viewtopic.php?f=20&t=9283&p=39552#p39552
Users browsing this forum: No registered users and 29 guests
