I am using internal_reciever example for two days,
And there's one problem i am facing is it sometimes stucks at
(1806) mesh: 2626<MESH_NEW_ROOT_VOTE_DONE>MESH_VOTE_STOP_FROM_HEALING, s_vote_scan_times:0
sometimes it connects to the wifi router but many times it is not?!
I have read the documentation several times but MESH_VOTE_STOP_FROM_HEALING is not mentioned anywhere...
here's the log..
`I (1296) mesh_main: <MESH_EVENT_STARTED>ID:77:77:77:77:77:77
W (1296) mesh: [mesh_set_io_process,1359] MESH_IO_CFG_SELF_ORGANIZED
W (1306) mesh: [mesh_nwk_task_main,3102] <MESH_NWK_IO_CFG>MESH_IO_CFG_SELF_ORGANIZED
I (1306) mesh: <3141>self organized disabled
I (1316) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/0.ing]router found
I (1326) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-48], mine:0, voter:0
I (1326) mesh: 952, vote myself, router rssi:-48 > voted rc_rssi:-120
I (1336) mesh: [SCAN:1/10]rc[128][30:ae:a4:45:b1:ad,-48], self[30:ae:a4:45:b1:ac,-48,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (1356) mesh: [SCAN][ch:6]AP:0, otherID:0, idle:0, mAP:0, root:0, top mAP:0[Layer:0/1.ing]
I (1356) mesh: [FAIL][2]root:1, fail:1, normal:0
I (1366) mesh_main: mesh starts successfully, heap:193828, root not fixed
I (1716) mesh: 2019self-organized is disabled, users shall read out scan results by themselves.
I (1716) mesh_main: <MESH_EVENT_SCAN_DONE>number:5
I (1716) mesh_main: [0]VEGG, 28:3b:82:65:b7:19, channel:6, rssi:-44
I (1726) mesh_main: [1]WiFi Link Studio, 98:d0:4a:63:68, channel:6, rssi:-95
I (1736) mesh_main: [2]ARIZONA, ec:01:ee:bc:c7:19, channel:6, rssi:-89
I (1736) mesh_main: [3]jp consultancy, 00:1e:a6:a8:5e:00, channel:6, rssi:-88
I (1746) mesh_main: [4]SMWIFI, 00:17:7c:7e:22:a1, channel:6, rssi:-84
W (1756) mesh_main: no parent found, enable self-organized networking.
I (2126) mesh: [SCAN][ch:6]AP:6, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (2126) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-49], mine:0, voter:0
I (2126) mesh: [SCAN:2/10]rc[128][30:ae:a4:45:b1:ad,-49], self[30:ae:a4:45:b1:ac,-49,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (2506) mesh: [SCAN][ch:6]AP:5, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (2506) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-64], mine:0, voter:0
I (2516) mesh: [SCAN:3/10]rc[128][30:ae:a4:45:b1:ad,-64], self[30:ae:a4:45:b1:ac,-64,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (2886) mesh: [SCAN][ch:6]AP:5, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (2886) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-58], mine:0, voter:0
I (2896) mesh: [SCAN:4/10]rc[128][30:ae:a4:45:b1:ad,-58], self[30:ae:a4:45:b1:ac,-58,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (3266) mesh: [SCAN][ch:6]AP:6, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (3266) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-52], mine:0, voter:0
I (3276) mesh: [SCAN:5/10]rc[128][30:ae:a4:45:b1:ad,-52], self[30:ae:a4:45:b1:ac,-52,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (3646) mesh: [SCAN][ch:6]AP:6, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (3656) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-41], mine:0, voter:0
I (3656) mesh: [SCAN:6/10]rc[128][30:ae:a4:45:b1:ad,-41], self[30:ae:a4:45:b1:ac,-41,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (4036) mesh: [SCAN][ch:6]AP:4, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (4036) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-42], mine:0, voter:0
I (4036) mesh: [SCAN:7/10]rc[128][30:ae:a4:45:b1:ad,-42], self[30:ae:a4:45:b1:ac,-42,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (4416) mesh: [VOTE][ch:6]AP:3, otherID:0, idle:0, mAP:1, root:0, [Layer:1]router found
I (4416) mesh: 2626<MESH_NEW_ROOT_VOTE_DONE>MESH_VOTE_STOP_FROM_HEALING, s_vote_scan_times:0
ets Jun 8 2016 00:22:57
# And here's the connected log after i do reset?
`I (1305) mesh_main: <MESH_EVENT_STARTED>ID:77:77:77:77:77:77
W (1305) mesh: [mesh_set_io_process,1359] MESH_IO_CFG_SELF_ORGANIZED
W (1305) mesh: [mesh_nwk_task_main,3102] <MESH_NWK_IO_CFG>MESH_IO_CFG_SELF_ORGANIZED
I (1315) mesh: <3141>self organized disabled
I (1315) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/0.ing]router found
I (1325) mesh_main: mesh starts successfully, heap:193940, root not fixed
I (1325) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-54], mine:0, voter:0
I (1335) mesh: 952, vote myself, router rssi:-54 > voted rc_rssi:-120
I (1345) mesh: [SCAN:1/10]rc[128][30:ae:a4:45:b1:ad,-54], self[30:ae:a4:45:b1:ac,-54,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (1365) mesh: [SCAN][ch:6]AP:0, otherID:0, idle:0, mAP:0, root:0, top mAP:0[Layer:0/1.ing]
I (1365) mesh: [FAIL][2]root:1, fail:1, normal:0
I (1725) mesh: 2019self-organized is disabled, users shall read out scan results by themselves.
I (1725) mesh_main: <MESH_EVENT_SCAN_DONE>number:8
I (1725) mesh_main: [0]WiFi Link Studio, 98:d0:4a:63:68, channel:6, rssi:-90
I (1735) mesh_main: [1]SMWIFI, 00:17:7c:7e:22:a1, channel:6, rssi:-91
I (1745) mesh_main: [2]VEGG, 28:3b:82:65:b7:19, channel:6, rssi:-52
I (1745) mesh_main: [3]DIGISOL, 00:17:7c:6b:fb:42, channel:6, rssi:-94
I (1755) mesh_main: [4]jp consultancy, 00:1e:a6:a8:5e:00, channel:6, rssi:-90
I (1765) mesh_main: [5], 00:17:7c:6b:fb:43, channel:6, rssi:-91
I (1775) mesh_main: [6]ARIZONA, ec:01:ee:bc:c7:19, channel:6, rssi:-90
I (1775) mesh_main: [7]GMB GROUP, 00:17:7c:7e:55:c6, channel:6, rssi:-91
W (1785) mesh_main: no parent found, enable self-organized networking.
I (2155) mesh: [SCAN][ch:6]AP:8, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (2155) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-52], mine:0, voter:0
I (2165) mesh: [SCAN:2/10]rc[128][30:ae:a4:45:b1:ad,-52], self[30:ae:a4:45:b1:ac,-52,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (2535) mesh: [SCAN][ch:6]AP:7, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (2535) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-50], mine:0, voter:0
I (2545) mesh: [SCAN:3/10]rc[128][30:ae:a4:45:b1:ad,-50], self[30:ae:a4:45:b1:ac,-50,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (2915) mesh: [SCAN][ch:6]AP:6, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (2915) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-50], mine:0, voter:0
I (2925) mesh: [SCAN:4/10]rc[128][30:ae:a4:45:b1:ad,-48], self[30:ae:a4:45:b1:ac,-50,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (3295) mesh: [SCAN][ch:6]AP:5, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (3305) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-47], mine:0, voter:0
I (3305) mesh: [SCAN:5/10]rc[128][30:ae:a4:45:b1:ad,-47], self[30:ae:a4:45:b1:ac,-47,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (3685) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (3685) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-69], mine:0, voter:0
I (3685) mesh: [SCAN:6/10]rc[128][30:ae:a4:45:b1:ad,-69], self[30:ae:a4:45:b1:ac,-69,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (4065) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (4065) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-70], mine:0, voter:0
I (4065) mesh: [SCAN:7/10]rc[128][30:ae:a4:45:b1:ad,-70], self[30:ae:a4:45:b1:ac,-70,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (4445) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (4445) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-81], mine:0, voter:0
I (4445) mesh: [SCAN:8/10]rc[128][30:ae:a4:45:b1:ad,-81], self[30:ae:a4:45:b1:ac,-81,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (4825) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (4825) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-79], mine:0, voter:0
I (4835) mesh: [SCAN:9/10]rc[128][30:ae:a4:45:b1:ad,-79], self[30:ae:a4:45:b1:ac,-79,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (5205) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (5205) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-77], mine:0, voter:0
I (5215) mesh: 936, [0]my_vote_num:0, voter_num:0
I (5215) mesh: [SCAN:10/13+extra+]rc[128][30:ae:a4:45:b1:ad,-77], self[30:ae:a4:45:b1:ac,-77,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (5595) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (5595) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-76], mine:0, voter:0
I (5595) mesh: [SCAN:11/13+extra+]rc[128][30:ae:a4:45:b1:ad,-76], self[30:ae:a4:45:b1:ac,-76,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (5975) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (5975) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-73], mine:0, voter:0
I (5985) mesh: [SCAN:12/13+extra+]rc[128][30:ae:a4:45:b1:ad,-73], self[30:ae:a4:45:b1:ac,-73,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (6355) mesh: [SCAN][ch:6]AP:1, otherID:0, idle:0, mAP:1, root:0, top mAP:0[Layer:0/1.ing]router found
I (6355) mesh: 916, [SCAN]init rc[30:ae:a4:45:b1:ad,-78], mine:0, voter:0
I (6365) mesh: [SCAN:13/13+extra+]rc[128][30:ae:a4:45:b1:ad,-78], self[30:ae:a4:45:b1:ac,-78,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:0.90][128,1,30:ae:a4:45:b1:ad]
I (6375) mesh: [DONE]connect to router:VEGG, rssi:-78, 28:3b:82:65:b7:19[layer:1], rc[30:ae:a4:45:b1:ad/-78]
I (12525) wifi: ap channel adjust o:6,1 n:6,2
I (12525) wifi: n:6 2, o:6 0, ap:6 2, sta:6 2, prof:6
I (13505) wifi: state: init -> auth (b0)
I (13515) wifi: state: auth -> assoc (0)
I (13525) wifi: state: assoc -> run (10)
I (13595) wifi: connected with VEGG, channel 6
I (13595) wifi: pm start, type: 0
E (13595) event: invalid static ip
I (13595) mesh_main: <MESH_EVENT_PARENT_CONNECTED>layer:0-->1, parent:28:3b:82:65:b7:19, ID:77:77:77:77:77:77
I (13605) mesh_main: <MESH_EVENT_ROOT_ADDRESS>root address:30:ae:a4:45:b1:ad
I (15625) mesh_main: <MESH_EVENT_ROOT_GOT_IP>sta ip: 192.168.0.9, mask: 255.255.255.0, gw: 192.168.0.1
I (15625) event: sta ip: 192.168.0.9, mask: 255.255.255.0, gw: 192.168.0.1
Re: MESH_NEW_ROOT_VOTE_DONE>MESH_VOTE_STOP_FROM_HEALING,
The manual_networking example.
This is a bug when add the manual networking function.
It's happening in both internal_transciever and manual networking stuck at this thing till 7 days!ESP_yudong wrote:The manual_networking example.
Yes, both example could reproduce this issue.
It will happene when scan AP number is 3.
This bug has already fixed but not merged.
Sorry for long time waiting.
[VOTE][ch:6]AP:3,
Please don't say sorry,
We all are here to help each other out,
Have you merged the problem?
ESP_yudong wrote:Yes, both example could reproduce this issue.
It will happene when scan AP number is 3.This bug has already fixed but not merged.Code: Select all
[VOTE][ch:6]AP:3,
Users browsing this forum: No registered users and 16 guests
