Hi
I am build a test application with ESP32 MDF in order to get familiar with the API. A configure a single node with a fixed WiFi network. The device can connect to wifi, but a always get the error:"invalid static ip"
Here goes my log:
I (15327) wifi: n:1 1, o:1 0, ap:1 1, sta:1 0, prof:1
I (16317) wifi: state: init -> auth (b0)
I (16322) wifi: state: auth -> assoc (0)
I (16328) wifi: state: assoc -> run (10)
I (16364) wifi: connected with Skynet, channel 1
I (16365) wifi: pm start, type: 0
E (16366) event: invalid static ip <---------------------------
W (16367) wifi: [beacon]new interval:300ms
I (16370) mdf_wifi_mesh: [esp_mesh_event_cb, 70]:esp_mesh_event_cb event.id: 7
I (16377) mdf_wifi_mesh: [esp_mesh_event_cb, 74]:wifi connected
I (16386) mdf_wifi_mesh: [esp_mesh_event_cb, 70]:esp_mesh_event_cb event.id: 14
I (18242) mdf_wifi_mesh: [esp_mesh_event_cb, 70]:esp_mesh_event_cb event.id: 17
I (18242) mdf_wifi_mesh: [esp_mesh_event_cb, 131]:wifi get ip
I (18246) event: sta ip: 192.168.0.8, mask: 255.255.255.0, gw: 192.168.0.1
Is there a way to eliminate the error?
BR Gilberto
invalid static ip
Re: invalid static ip
Don't worry about this line of logs.
Normally we don't need lwip or dhcp between mesh nodes, but tcpip_adapter_init() must be called before wifi start. So dhcp was stopped when mesh start. You can set a valid static ip if you really don't want to see this.
If you use invalid static ip then your whole system would be failed to do work. so use valid ip address to work smoothly. you can visit https://errorcode0x.com/linksys-e1200-r ... tup-guide/ to set a a valid ip address. with the invalid ip you can not connect with another device, you cannot do much in setting and you cannot share anything . a valid ip address always allow you to each and every thing. your work would be fruitful.
Users browsing this forum: No registered users and 29 guests
