WiFi mesh : broadcast & multicast policy
Ankit53
Postby Ankit53 » Tue Feb 12, 2019 9:50 am
What is broadcast and multicast policy in N layer WiFI mesh network?
If Root is broadcasting frame , dose it reach to end nodes of network or just received by the ones who are in direct connection range of root?
Thank You,
Ankit Siddhapura
leenowell
Re: WiFi mesh : broadcast & multicast policy
Postby leenowell » Tue Feb 12, 2019 7:27 pm
I think the answer to your question is in the data transmission of the mesh docs here
https://docs.espressif.com/projects/esp ... ansmission
thanks
Lee.
Ankit53
Postby Ankit53 » Thu Feb 14, 2019 10:53 am
Thank You Lee!
is this broad cast ans multicast policy are cloned from WiFi specification or ESP has defined their own for ESP-mesh only?
Is Multicast-Group Address (01:00:5E:xx:xx:xx) customized feature of ESP32 mesh or in WiFi specification described somewhere? I could not find same in specification so.
Regards,
Ankit Siddhapura
ESP_yudong
Postby ESP_yudong » Fri Feb 15, 2019 12:30 pm
Hi Ankit,
In my mind, the policy in document is for ESP_MESH only. It only works in mesh layer,although the Multicast-Group Address is same as WiFi specification.
Users browsing this forum: No registered users and 30 guests
