I'm new to the ESP. But I was asking myself the question if it would be possible to control my Area Switch via a esp32 and Home Assistant. See photo's. You can see it's a simple manual switch. In the box there is lots of place left for an esp and a battery. In the garden I've got wifi.
So would it be possible to move the switch remotely?
Thanks,
James
Controlling Husqvarna Area Switch
- 20231017_155957.jpg (8.36 MiB) Viewed 33303 times
- 20231017_155949.jpg (8.26 MiB) Viewed 33303 times
- 20231017_155941.jpg (8.03 MiB) Viewed 33303 times
Re: Controlling Husqvarna Area Switch
Probably. You'd use a relay to replace the switch, and an ESP32 to control the relay. Suggest looking into ESPHome if you want easy integration with Home Assistant.
Users browsing this forum: No registered users and 96 guests
