Ethernet to WiFi data forwarding demo code not working on ESP32-EVB
bhakti
Postby bhakti » Fri Oct 05, 2018 7:31 am
Hello Espressif,
I am working on ESP32-EVB olimex board with msys32 environment on windows, example codes of Ethernet and wifi worked on board.
Now I need to use Ethernet to WiFi data forwarding demo code( https://github.com/espressif/esp-iot-so ... s/eth2wifi) for our application. This code is particularly for LAN8720, So
1) I have edited source and header files for LAN8710A.
2) changed phy address to 0.
3) Edited Wifi ssid and password accordingly.
3) looks like PHY is powered in hardware itself not using GPIO for power, but I have not changed anything related to this in code.
After flash and monitor device is Rebooting continuously and error is
Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhanded.
Please help and suggest if I am missing something.
Thanks.
/* Ethernet to WiFi data forwarding Example
   For other examples please check:
   https://github.com/espressif/esp-iot-solution/tree/master/examples
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
#include <string.h>
#include "freertos/task.h"
#include "esp_event_loop.h"
#include "esp_event.h"
#include "esp_log.h"
#include "esp_eth.h"
#include "esp_wifi.h"
#include "esp_wifi_internal.h"
#include "nvs_flash.h"
#ifdef CONFIG_PHY_LAN8720
#include "eth_phy/olimex_lan8710.h"
#define DEFAULT_ETHERNET_PHY_CONFIG phy_lan8710_default_ethernet_config
#endif
#ifdef CONFIG_PHY_TLK110
#include "eth_phy/phy_tlk110.h"
#define DEFAULT_ETHERNET_PHY_CONFIG phy_tlk110_default_ethernet_config
#endif
static const char* TAG = "eth2wifi_demo";
#define PIN_PHY_POWER CONFIG_PHY_POWER_PIN
#define PIN_SMI_MDC   CONFIG_PHY_SMI_MDC_PIN
#define PIN_SMI_MDIO  CONFIG_PHY_SMI_MDIO_PIN
typedef struct {
    void* buffer;
    uint16_t len;
    void* eb;
} tcpip_adapter_eth_input_t;
static bool mac_is_set = false;
static xQueueHandle eth_queue_handle;
static bool wifi_is_connected = false;
static bool ethernet_is_connected = false;
static uint8_t eth_mac[6];
#ifdef CONFIG_PHY_USE_POWER_PIN
/* This replaces the default PHY power on/off function with one that
   also uses a GPIO for power on/off.
   If this GPIO is not connected on your device (and PHY is always powered), you can use the default PHY-specific power
   on/off function rather than overriding with this one.
static void phy_device_power_enable_via_gpio(bool enable)
    assert(DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable);
    if (!enable) {
        /* Do the PHY-specific power_enable(false) function before powering down */
        DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable(false);
    gpio_pad_select_gpio(PIN_PHY_POWER);
    gpio_set_direction(PIN_PHY_POWER, GPIO_MODE_OUTPUT);
    if (enable == true) {
        gpio_set_level(PIN_PHY_POWER, 1);
        ESP_LOGD(TAG, "phy_device_power_enable(TRUE)");
    } else {
        gpio_set_level(PIN_PHY_POWER, 0);
        ESP_LOGD(TAG, "power_enable(FALSE)");
    // Allow the power up/down to take effect, min 300us
    vTaskDelay(1);
    if (enable) {
        /* Run the PHY-specific power on operations now the PHY has power */
        DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable(true);
	phy_lan8710_power_enable(enable);
#endif
static void ethernet2wifi_mac_status_set(bool status)
    mac_is_set = status;
static bool ethernet2wifi_mac_status_get(void)
    return mac_is_set;
static void eth_gpio_config_rmii(void)
    // RMII data pins are fixed:
    // TXD0 = GPIO19
    // TXD1 = GPIO22
    // TX_EN = GPIO21
    // RXD0 = GPIO25
    // RXD1 = GPIO26
    // CLK == GPIO0
    phy_rmii_configure_data_interface_pins();
    // MDC is GPIO 23, MDIO is GPIO 18
    phy_rmii_smi_configure_pins(PIN_SMI_MDC, PIN_SMI_MDIO);
static esp_err_t tcpip_adapter_eth_input_sta_output(void* buffer, uint16_t len, void* eb)
    tcpip_adapter_eth_input_t msg;
    msg.buffer = buffer;
    msg.len = len;
    msg.eb = eb;
    if (xQueueSend(eth_queue_handle, &msg, portMAX_DELAY) != pdTRUE) {
        return ESP_FAIL;
    return ESP_OK;
static void eth_task(void* pvParameter)
    for (;;) {
        if (xQueueReceive(eth_queue_handle, &msg, (portTickType)portMAX_DELAY) == pdTRUE) {
            if (msg.len > 0) {
                if (!ethernet2wifi_mac_status_get()) {
                    memcpy(eth_mac, (uint8_t*)msg.buffer + 6, sizeof(eth_mac));
                    ESP_ERROR_CHECK(esp_wifi_start());
#ifdef CONFIG_ETH_TO_STATION_MODE
                    esp_wifi_set_mac(WIFI_IF_STA, eth_mac);
                    esp_wifi_connect();
#else
                    esp_wifi_set_mac(WIFI_IF_AP, eth_mac);
#endif
                    ethernet2wifi_mac_status_set(true);
                if (wifi_is_connected) {
                    esp_wifi_internal_tx(ESP_IF_WIFI_STA, msg.buffer, msg.len - 4);
#else
                    esp_wifi_internal_tx(ESP_IF_WIFI_AP, msg.buffer, msg.len - 4);
#endif
            esp_eth_free_rx_buf(msg.buffer);
static void initialise_wifi(void)
    wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
    ESP_ERROR_CHECK(esp_wifi_init_internal(&cfg));
    ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = CONFIG_DEMO_SSID,
            .password = CONFIG_DEMO_PASSWORD,
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config));
#else
        .ap = {
            .ssid_len = strlen(CONFIG_DEMO_SSID),
            .max_connection = 1,
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
#endif
static void initialise_ethernet(void)
    eth_config_t config = DEFAULT_ETHERNET_PHY_CONFIG;
    /* Set the PHY address in the example configuration */
    config.phy_addr = CONFIG_PHY_ADDRESS;
    config.gpio_config = eth_gpio_config_rmii;
    config.tcpip_input = tcpip_adapter_eth_input_sta_output;
    /* Replace the default 'power enable' function with an example-specific
       one that toggles a power GPIO. */
    config.phy_power_enable = phy_device_power_enable_via_gpio;
#endif
    esp_eth_init_internal(&config);
    esp_eth_enable();
	printf("Task 1.....here....");
	vTaskDelay(1000);
static esp_err_t tcpip_adapter_sta_input_eth_output(void* buffer, uint16_t len, void* eb)
    if (ethernet_is_connected) {
        esp_eth_tx(buffer, len);
    esp_wifi_internal_free_rx_buffer(eb);
    return ESP_OK;
static esp_err_t tcpip_adapter_ap_input_eth_output(void* buffer, uint16_t len, void* eb)
    return ESP_OK;
static esp_err_t event_handler(void* ctx, system_event_t* event)
    switch (event->event_id) {
        case SYSTEM_EVENT_STA_START:
            printf("SYSTEM_EVENT_STA_START\r\n");
            break;
        case SYSTEM_EVENT_STA_CONNECTED:
            printf("SYSTEM_EVENT_STA_CONNECTED\r\n");
            wifi_is_connected = true;
            esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_STA, (wifi_rxcb_t)tcpip_adapter_sta_input_eth_output);
            break;
        case SYSTEM_EVENT_STA_GOT_IP:
            printf("SYSTEM_EVENT_STA_GOT_IP\r\n");
            break;
        case SYSTEM_EVENT_STA_DISCONNECTED:
            printf("SlYSTEM_EVENT_STA_DISCONNECTED\r\n");
            esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_STA, NULL);
            esp_wifi_connect();
            break;
        case SYSTEM_EVENT_AP_STACONNECTED:
            printf("SYSTEM_EVENT_AP_STACONNECTED\r\n");
            esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_AP, (wifi_rxcb_t)tcpip_adapter_ap_input_eth_output);
            break;
        case SYSTEM_EVENT_AP_STADISCONNECTED:
            printf("SYSTEM_EVENT_AP_STADISCONNECTED\r\n");
            esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_AP, NULL);
            break;
        case SYSTEM_EVENT_ETH_CONNECTED:
            printf("SYSTEM_EVENT_ETH_CONNECTED\r\n");
            ethernet_is_connected = true;
            break;
        case SYSTEM_EVENT_ETH_DISCONNECTED:
            printf("SYSTEM_EVENT_ETH_DISCONNECTED\r\n");
            ethernet2wifi_mac_status_set(false);
            break;
        default:
            break;
    return ESP_OK;
void app_main()
    ESP_ERROR_CHECK(nvs_flash_init());
    eth_queue_handle = xQueueCreate(CONFIG_DMA_RX_BUF_NUM, sizeof(tcpip_adapter_eth_input_t));
    xTaskCreate(eth_task, "eth_task", 2048, NULL, (tskIDLE_PRIORITY + 2), NULL);
    esp_event_loop_init(event_handler, NULL);
    initialise_ethernet();
    initialise_wifi();
output on monitor
Thanks and Best regards,
Bhakti Deshpande.
costaud
Re: Ethernet to WiFi data forwarding demo code not working on ESP32-EVB
Postby costaud » Wed Nov 14, 2018 10:42 am
It would be better to post esp-iot-solution related bug report in github issues.
iot-lqq
Postby iot-lqq » Fri Nov 16, 2018 2:24 pm
Tested what you said.
Since there is no device for this phy, the test demo is run using only the module.
After the modification, your phenomenon did not appear, but the print will be repeated "emac resetting ...."
You can check the hardware connection and try to run the individual modules to increase the cause of the print information location problem.
bhakti
Postby bhakti » Tue Mar 12, 2019 7:23 am
Thank you very much for reply.
That issue was related to setting library path. That worked long back.sorry for late update.
Bhakti Deshpande.
Users browsing this forum: No registered users and 36 guests
