ESPNOW access via pc or phone
radhu_pr
Postby radhu_pr » Tue Dec 25, 2018 6:59 am
I tried ESP32 ESPNOW data transfer bewteen four esp32 and it works very fine. If i need to connect this network to pc or android phone to control the data.Is it enough simply by adding their Mac id? if so it s possible to receive data in pc side or phone by simply access through mac id and send data? or any other way? if so will espnow(which kept as master support both at simultaneously?
I need to control each room loads from my phone through wifi.i kept each esp32 in a room.estoo
Your suggestions will help me out lot.
Regards
Radha
radhu_pr
Re: ESPNOW access via pc or phone
Postby radhu_pr » Mon Jan 07, 2019 5:01 am
Wondering is it no body tried ESP-Now with pc or andoid ? Your replies will be very useful to complete my project.
Regards
Radha
Postby ESP_Sprite » Tue Jan 08, 2019 11:14 am
ESP-Now packets essentially are WiFi management frames. I have no idea if there's a solution on PC or phone that can capture or send those frames, but if there is, you could use that to receive/format ESP-Now frames.
jerome
Postby jerome » Sat Mar 16, 2019 9:03 am
Hi
I was wondering if you succeeded in connecting a ESPNOW network to a mobile app ?
cmskipsey
Postby cmskipsey » Thu Sep 19, 2019 6:23 am
Did you make any progress on this? I guess theoretically you could use the phones Mac address, send ESP-NOW frames and find a way to look at the raw frames on the phones wifi interface. No idea if Android SDK let's you get that close to the metal though...
MStackoverflow
Postby MStackoverflow » Tue Dec 03, 2019 6:58 pm
I guess if you want a quick hack you could add an ESP32/ESP8266 which bridge one of the esp on the network via bluetooth, then send the information to your local network, which could be controlled by your phone. Or, I don't know if it's possible, take ESP-NOW messages and send it directly to a wifi local network simultaneously.
ipconfiger
Postby ipconfiger » Sun Dec 11, 2022 7:03 am
I found a project: https://hackaday.io/project/161896-linux-espnow
well be helpful
cbehning
Postby cbehning » Wed Apr 12, 2023 7:37 am
I have begun reviewing the link above for a project where the computer just needs to broadcast. So far it looks like it will work. I can post my results once finished
mpoonawala
Postby mpoonawala » Tue Jan 16, 2024 5:46 pm
Did you find a way to connect it with mobile app?
Users browsing this forum: No registered users and 82 guests
