如何获取ESP32-LyraT-Mini开发板出厂固件的源代码
cylnpy
Postby cylnpy » Mon Mar 25, 2024 6:18 am
ESP32-LyraT-Mini开发板出厂固件的源代码在哪里下载。
cylnpy
Re: 如何获取ESP32-LyraT-Mini开发板出厂固件的源代码
Postby cylnpy » Tue Mar 26, 2024 5:42 am
esp32 Lyrat-mini dueros v1 版本源码在哪里能找得到。
cylnpy
Postby cylnpy » Tue Mar 26, 2024 6:30 am
这是开发板上的log信息,但是找不到源码例程在哪里。
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:6216
load:0x40078000,len:8588
load:0x40080000,len:6652
entry 0x40080340
[0;32mI (29) boot: ESP-IDF v3.1.4-69-g3e666077f 2nd stage bootloader[0m
[0;32mI (29) boot: compile time 20:49:25[0m
[0;32mI (31) boot: Enabling RNG early entropy source...[0m
[0;32mI (35) qio_mode: Enabling default flash chip QIO[0m
[0;32mI (40) boot: SPI Speed : 80MHz[0m
[0;32mI (44) boot: SPI Mode : QIO[0m
[0;32mI (48) boot: SPI Flash Size : 4MB[0m
[0;32mI (53) boot: Partition Table:[0m
[0;32mI (56) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (63) boot: 0 nvs WiFi data 01 02 00009000 00004000[0m
[0;32mI (71) boot: 1 otadata OTA data 01 00 0000d000 00002000[0m
[0;32mI (78) boot: 2 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (86) boot: 3 wifi OTA app 00 10 00010000 00300000[0m
[0;32mI (93) boot: 4 Iram0 Unknown data 01 20 00310000 00020000[0m
[0;32mI (101) boot: 5 Dram0 Unknown data 01 21 00330000 00020000[0m
[0;32mI (108) boot: 6 Dram1 Unknown data 01 22 00350000 0001c000[0m
[0;32mI (116) boot: 7 flashTone NVS keys 01 04 00380000 0007d000[0m
[0;32mI (123) boot: 8 profile Unknown data 01 ff 003fe000 00001000[0m
[0;32mI (131) boot: 9 flashUri Unknown data 01 05 003ff000 00001000[0m
[0;32mI (139) boot: End of partition table[0m
[0;32mI (143) boot: No factory image, trying OTA 0[0m
[0;32mI (148) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x873d0 (553936) map[0m
[0;32mI (301) esp_image: segment 1: paddr=0x000973f8 vaddr=0x3ffb0000 size=0x04340 ( 17216) load[0m
[0;32mI (306) esp_image: segment 2: paddr=0x0009b740 vaddr=0x40080000 size=0x00400 ( 1024) load[0m
[0;32mI (308) esp_image: segment 3: paddr=0x0009bb48 vaddr=0x40080400 size=0x044c8 ( 17608) load[0m
[0;32mI (322) esp_image: segment 4: paddr=0x000a0018 vaddr=0x400d0018 size=0x1666a0 (1468064) map[0m
[0;32mI (708) esp_image: segment 5: paddr=0x002066c0 vaddr=0x400848c8 size=0x15630 ( 87600) load[0m
[0;32mI (735) esp_image: segment 6: paddr=0x0021bcf8 vaddr=0x400c0000 size=0x0013c ( 316) load[0m
[0;32mI (751) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (751) boot: Disabling RNG early entropy source...[0m
[0;32mI (751) spiram: SPI RAM mode: flash 80m sram 80m[0m
[0;32mI (756) spiram: PSRAM initialized, cache is in low/high (2-core) mode.[0m
[0;32mI (764) cpu_start: Pro cpu up.[0m
[0;32mI (767) cpu_start: Starting app cpu, entry point is 0x4008167c[0m
[0;32mI (0) cpu_start: App cpu up.[0m
[0;32mI (1242) spiram: SPI SRAM memory test OK[0m
[0;32mI (1243) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (1243) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m
[0;32mI (1250) heap_init: At 3FFBC758 len 000238A8 (142 KiB): DRAM[0m
[0;32mI (1255) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM[0m
[0;32mI (1262) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (1269) heap_init: At 40099EF8 len 00006108 (24 KiB): IRAM[0m
[0;32mI (1275) cpu_start: Pro cpu start user code[0m
[0;32mI (1279) spiram: Adding pool of 4096K of external SPI memory to heap allocator[0m
[0;32mI (1593) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations[0m
[0;32mI (38) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
[0;32mI (39) gpio: GPIO[22]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 [0m
[0;32mI (48) gpio: GPIO[27]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 [0m
[0;32mI (78) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3[0m
[0;32mI (79) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3[0m
[0;32mI (83) I2S: APLL: Req RATE: 48000, real rate: 47999.961, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 12287990.000, SCLK: 1535998.750000, diva: 1, divb: 0[0m
[0;32mI (95) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3[0m
[0;32mI (102) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3[0m
[0;32mI (109) I2S: PLL_D2: Req RATE: 16000, real rate: 16025.000, BITS: 16, CLKM: 39, BCK: 8, MCLK: 4096000.000, SCLK: 512800.000000, diva: 64, divb: 4[0m
[0;32mI (123) DRV8311: Enter into es8311_Codec_Startup()
[0m
[0;32mI (134) DRV8311: ES8311 in Slave mode
[0m
[0;32mI (136) DRV8311: Enter into es8311_pcm_hw_params()
[0m
[0;31mE (151) DRV8311: Es8311 Write Reg error[0m
[0;31mE (152) DRV8311: Es7243 Write Reg error[0m
[0;31mE (155) DRV8311: Es7243 Write Reg error[0m
[0;31mE (159) DRV8311: Es7243 Write Reg error[0m
[0;31mE (164) DRV8311: Es7243 Write Reg error[0m
[0;31mE (168) DRV8311: Es7243 Write Reg error[0m
[0;31mE (172) DRV8311: Es7243 initialize failed![0m
[0;32mI (177) DRV8311: Exit es8311_Codec_Startup()
[0m
[0;32mI (184) DRV8311: ES8311 in I2S Format[0m
[0;32mI (191) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 [0m
[0;32mI (196) DRV8311: SET: volume:153
[0m
[0;32mI (200) MEDIA_HAL: I2S_OUT_VOL_DEFAULT[60][0m
[0;32mI (205) AUDIO_MAIN: CONFIG_CODEC_CHIP_IS_ES8311[0m
----------------------------- ESP32 Lyrat-Mini Dueros V1-----------------------------
| Player_Version 0.95 |
| Compile date: Jul 3 2019-22:07:21 |
[0;32mI (320) BROADCAST: func:BroadcastInit, list=0x3ffc5044, que=0x0[0m
[0;32mI (320) I2S_READER: CreateI2sStreamReader[0m
[0;32mI (321) I2S_WRITER: CreateI2sStreamWriter[0m
[0;32mI (325) TONE_PLAYER: TonePlayerCreate
[0m
[0;32mI (330) PLAYLIST_MANAGER: Audio Playlist Manager Create
[0m
[0;32mI (336) FLASH_TRACKER: FlashTracker Create[0m
[0;32mI (341) SDCARD_TRACKER: Create[0m
[0;32mI (344) PLAYLIST_MANAGER: Active[0m
[0;32mI (348) FLASH_TRACKER: FlashTracker Active
[0m
[0;32mI (353) PLAYLIST_HELPER: playlist lock = [[0x3ffc5e0c]][0m
[0;32mI (360) PLAYLIST_HELPER: PlaylistOpen file handle,addr: 0x3ffc5e78 (line: 63)[0m
[0;32mI (367) SDCARD_TRACKER: Active[0m
[0;32mI (371) PLAYLIST_HELPER: playlist lock = [[0x3ffc5f68]][0m
[0;33mW (377) SOFT_CODEC: CodecStop, have no codec instance,0x0[0m
[0;33mW (383) SOFT_CODEC: CodecStop, have no codec instance,0x0[0m
[0;32mI (389) MEDIA_CTRL: Media started, and wait, ctrl addr=3f800040[0m
[0;32mI (397) I2S: APLL: Req RATE: 48000, real rate: 47999.961, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 12287990.000, SCLK: 1535998.750000, diva: 1, divb: 0[0m
[0;32mI (411) I2S: APLL: Req RATE: 48000, real rate: 47999.961, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 12287990.000, SCLK: 1535998.750000, diva: 1, divb: 0[0m
[0;32mI (423) DEVICE_CONTROLLER: Device Controller Create
[0m
[0;32mI (429) AUDIO_MAIN: Manually select audio lib[0m
[0;32mI (434) WIFI_CONFIG: WifiConfigCreate
[0m
[0;32mI (438) AUX_MANAGER: AuxManager Create[0m
[0;32mI (443) TOUCH_MANAGER: TouchManagerCreate
[0m
[0;32mI (448) SDCARD_MANAGER: SDCardManager Create
[0m
[0;32mI (453) DUEROS_SERVICE: DuerAppService has create[0m
[0;32mI (458) WIFI_CONFIG: WifiConfigActive, freemem 3339228[0m
I (465) wifi: wifi driver task: 3ffca284, prio:23, stack:3072, core=0
I (470) wifi: wifi firmware version: 065fbb7
I (474) wifi: config NVS flash: enabled
I (478) wifi: config nano formating: enabled
[0;32mI (482) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
[0;32mI (491) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
I (510) wifi: Init dynamic tx buffer num: 32
I (510) wifi: Init data frame dynamic rx buffer num: 32
I (511) wifi: Init management frame dynamic rx buffer num: 32
I (514) wifi: Init management short buffer num: 32
I (519) wifi: Init static tx buffer num: 6
I (523) wifi: Init static rx buffer size: 1600
I (527) wifi: Init static rx buffer num: 10
I (531) wifi: Init dynamic rx buffer num: 32
[0;32mI (588) phy: phy_version: 4008, 544f89f, Jan 24 2019, 14:54:06, 0, 0[0m
I (589) wifi: mode : sta (08:d1:f9:ed:26:2c)
[0;32mI (590) WIFI_CONFIG: +WIFI:STA_START[0m
[0;32mI (592) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 [0m
[0;32mI (1601) TOUCH_MANAGER: Button is adc[0m
[0;32mI (1601) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:2 [0m
[0;32mI (1603) AUXIN: auxin_detect_init create[0m
[0;32mI (1608) AUX_MANAGER: AuxManager Active[0m
[0;32mI (1613) TOUCH_CTRL_SERV: Touch Control Service running[0m
[0;32mI (1612) TOUCH_CTRL_SERV: touchControlActive[0m
[0;32mI (1618) BROADCAST: BroadcastRegister, list:0x3ffd780c, que:0x3ffd7698,index:0[0m
[0;32mI (1619) BROADCAST: BroadcastRegister, list:0x3ffd78d4, que:0x3ffd7828,index:0[0m
I (1594,tid:3ffdd150) >lightduer_session.c( 44):random = 75933
[0;32mI (1633) DUEROS_SERVICE: duerAppActive[0m
[0;32mI (1649) AUDIO_MAIN: [APP] This board is ESP_LYRAT_MINI_V1, freemem: 3237248...
[0m
[0;32mI (2636) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (2636) WIFI_CONFIG: Autoconnect[0m
[0;33mW (2642) DUEROS_SERVICE: DEVICE_NOTIFY_WIFI_DISCONNECTED[0m
[0;32mI (2644) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;32mI (6633) DUEROS_SERVICE: dueros_task has been running....[0m
M = 5
URI: i2s://16000:1@record.pcm#raw
[0;32mI (6643) RECORDER: I2S number is [0][0m
[0;32mI (6644) RECORDER: RecorderTask is running,src:1024,ch:2,rate:16000,dest:512,ch:1,rate:16000,line:159[0m
layer0 1 10
layer1 5 32
layer2 9 32
layer3 17 32
layer4 25 32
layer5 2 32
layer6 1 2
Quantized wakeNet5: wakeNet5_v1_hilexin_5_0.95_0.90
[0;32mI (6662) REC_ENG: ESP SR Engine, chunksize is 480锛? FRAME_SIZE:960, frequency:16000[0m
[0;31mE (6671) REC_ENG: Recorder Engine Running ..., vad_window=7, wakeup=3000 ms, vad_off=600 ms, threshold=90 ms, sensitivity=0[0m
[0;32mI (6682) REC_ENG: state idle[0m
[0;32mI (14707) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (14707) WIFI_CONFIG: Autoconnect[0m
[0;32mI (14719) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;31mE (22360) MEDIA_CTRL: No song,please add uri[0m
[0;32mI (22360) PL_MANAGER_HELPER: Playlist next or prev (line :56)[0m
[0;31mE (22360) UriList: in GetMusicName line:183 offSet 0 fileSize 0[0m
[0;31mE (22367) PL_MANAGER_HELPER: Get nothing -1[0m
[0;33mW (22372) MEDIA_CTRL: Next track does not exist[0m
[0;31mE (22377) MEDIA_CTRL: No song,please add uri[0m
[0;32mI (26784) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (26784) WIFI_CONFIG: Autoconnect[0m
[0;32mI (26796) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;32mI (38857) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (38857) WIFI_CONFIG: Autoconnect[0m
[0;32mI (38857) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;32mI (50927) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (50927) WIFI_CONFIG: Autoconnect[0m
[0;32mI (50928) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;32mI (63002) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (63003) WIFI_CONFIG: Autoconnect[0m
[0;32mI (63003) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;32mI (75073) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (75074) WIFI_CONFIG: Autoconnect[0m
[0;32mI (75074) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;32mI (87139) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (87140) WIFI_CONFIG: Autoconnect[0m
[0;32mI (87140) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;32mI (99205) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (99205) WIFI_CONFIG: Autoconnect[0m
[0;32mI (99206) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;32mI (111271) WIFI_CONFIG: +JAP:DISCONNECTED,0,201[0m
[0;32mI (111272) WIFI_CONFIG: Autoconnect[0m
[0;32mI (111272) WIFI_CONFIG: Autoconnect to nvs Wi-Fi ssid:ESP-Audio,pwd:esp123456.[0m
[0;33mW (111280) WIFI_CONFIG: Autoconnect Wi-Fi failed[0m
Brownout detector was trig
ESP_William
Postby ESP_William » Fri Mar 29, 2024 11:23 am
您好,
默认出厂固件烧录的是 ESP-ADF 的 Dueros ,建议您重新编译烧录,早期出厂固件因为 License 变更已经无法正常和 Dueros 交互。
Users browsing this forum: No registered users and 118 guests
