[Documentation Release] ESP32 Technical Reference
ESP_Angus
Re: [Documentation Release] ESP32 Technical Reference
Postby ESP_Angus » Thu Dec 29, 2016 12:59 am
Technical Reference is now V1.3, released December 23.
PDF link to latest (same as the link in the first post)
New in V1.3:
  • Added Chapter eFuse Controller;
  • Added Chapter RSA Accelerator;
  • Added Chapter Random Number Generator;
  • Updated Section I2C Controller Interrupt and Section I2C Controller Registers.
ESP_Angus
Postby ESP_Angus » Fri Jan 27, 2017 12:47 am
Technical Reference is now V1.4, released January 26.
New in V1.4:
  • Added Chapter SPI;
  • Added Chapter UART Controller;
ESP_Angus
Postby ESP_Angus » Wed Mar 01, 2017 11:00 pm
Technical Reference is now V1.5, released March 1.
New in V1.5:
  • Added Chapter I2S
WiFive
Postby WiFive » Tue Mar 07, 2017 3:22 pm
ESP_Angus wrote:Technical Reference is now V1.5, released March 1.
Encoding seems to be messed up again, can't search or copy text. Could in 1.4.
Postby ESP_Sprite » Wed Mar 08, 2017 1:43 am
Huh, I see. I'll inform the techdoc team.
ESP_Angus
Postby ESP_Angus » Wed Mar 08, 2017 3:50 am
The reference has been re-uploaded and searching should work again.
(As the file name doesn't change you may have to force a cache refresh.)
ESP_Angus
Postby ESP_Angus » Mon Apr 03, 2017 12:50 am
Technical Reference is now V1.6, released March 30.
New in V1.6:
  • Added Chapter SD/MMC Host Controller
  • Added register IO_MUX_PIN_CTRL in Chapter IO_MUX and GPIO Matrix.
ESP_Angus
Postby ESP_Angus » Fri May 05, 2017 1:48 am
Technical Reference is now V1.7. May the Fourth be with you.
New in V1.7:
  • Added Chapter On-Chip Sensors and Analog Signal Processing
  • Added Section Audio PLL
  • Updated Section eFuse Controller Register Summary;
  • Updated Sections I2S PDM and LCD MODE;
  • Updated Section Communication Format Supported by GP-SPI Slave.
ESP_Angus
Postby ESP_Angus » Tue Jun 13, 2017 4:30 am
Technical Reference is now V1.8.
New in V1.8:
  • Added Chapter ULP Co-processor
  • Added register I2S_STATE_REG in Chapter I2S
  • Updated Chapters IO_MUX and GPIO Matrix
ESP_Angus
Postby ESP_Angus » Wed Jul 19, 2017 11:01 pm
Oops, I missed some releases! TRM is now V2.1, released July 19.
New in V2.1:
Added Chapter PID Controller
Updated Chapter IO_MUX and GPIO_Matrix
New in V2.0:
Added Chapter SDIO Slave.
New in V1.9:
Updated Chapter IO_MUX and GPIO Matrix;
Added Chapter MCPWM.
Users browsing this forum: No registered users and 65 guests
