Technical Reference I2S Clock config section is confusing
WiFive
Postby WiFive » Sat Apr 01, 2017 9:20 am
For the configuration of I2S0 peripheral clock output: When PIN_CTRL[3:0] = 0x0, select and
output module clock on the CLK_OUT1 in the IO_MUX Pad Summary;
When PIN_CTRL[3:0] = 0x0 and PIN_CTRL[7:4] = 0x0, select and output module clock on the
CLK_OUT2 in the IO_MUX Pad Summary;
When PIN_CTRL[3:0] = 0x0 and PIN_CTRL[11:8] = 0x0; select and output module clock on the
CLK_OUT3 in the IO_MUX Pad Summary.
For the configuration of I2S1 peripheral clock output: When PIN_CTRL[3:0] = 0xF, select and
output module clock on CLK_OUT1-3. (R/W)
This is confusing.
Re: [Documentation Release] ESP32 Technical Reference
Postby rudi ;-) » Sat Apr 01, 2017 5:28 pm
This is confusing.
if you read between the lines:
( without warranty )
select and output module clock on the CLK_OUT1 in the IO_MUX Pad Summary;
means output clock: CLK_OUT1
select and output module clock on the CLK_OUT2 in the IO_MUX Pad Summary;
means output clock: CLK_OUT2
select and output module clock on the CLK_OUT3 in the IO_MUX Pad Summary.
means output clock: CLK_OUT3
select and output module clock on CLK_OUT1-3. (R/W)
means output clock: CLK_OUT1 CLK_OUT2 CLK_OUT3
one thing is not clear: (R/W)
means perhabs we can read ( check ) and write ( set ) on the register
But to search for a logical connection in register pins would be futile :)
I'm not in the i2s at the moment, i am waiting for the pSRAM module then start i2s
WiFive
Postby WiFive » Sat Apr 01, 2017 8:15 pm
Still confusing in color.
RoyceP
Re: Technical Reference I2S Clock config section is confusing
Postby RoyceP » Wed Jul 19, 2017 2:39 am
It sort of feels like getting the I2S peripheral clock out to feed the Master Clock input of an I2S DAC boils down to
PIN_FUNC_SELECT(PIN_CTRL, CLK_OUT1_S);
and then you get the clock on GPIO0.
Sound right?
It will be few days before I can actually try it, but I thought I'd check-in on this thread.
WiFive
Postby WiFive » Wed Jul 19, 2017 4:39 am
Section has not been updated.
iot-bits.com
Contact:
Postby iot-bits.com » Thu Jul 20, 2017 5:02 am
Here are settings that work (I used these to play 96kHz 24 bps stereo audio via a codec):
If you want to output clock for I2S0 to
CLK_OUT1, then set PIN_CTRL[3:0] = 0x0
CLK_OUT2, then set PIN_CTRL[3:0] = 0x0 and PIN_CTRL[7:4] = 0x0
CLK_OUT3, then set PIN_CTRL[3:0] = 0x0 and PIN_CTRL[11:8] = 0x0
If you want to output clock for I2S1 to
CLK_OUT1, then set PIN_CTRL[3:0] = 0xF
CLK_OUT2, then set PIN_CTRL[3:0] = 0xF and PIN_CTRL[7:4] = 0x0
CLK_OUT3, then set PIN_CTRL[3:0] = 0xF and PIN_CTRL[11:8] = 0x0
The rest of the bits are not documented, so should be treated as reserved.
- Pratik
:geek: Just another hobbyist and consultant
WiFive
Postby WiFive » Thu Jul 20, 2017 9:18 am
Thanks, so bits that are not set to 0 should be set to 1? All 3 nybbles should be either 0 or F?
How do you output I2S0 clock on CLK_OUT1 and I2S1 clock on CLK_OUT2? Or you can only route one clock to gpio matrix?
RoyceP
Postby RoyceP » Sat Jul 22, 2017 6:48 pm
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_CLK_OUT1);
The above got the clock. It is 40Mhz which is not quite what my DAC wants, but that is another story.
WiFive
Postby WiFive » Sat Jul 22, 2017 7:12 pm
I dont think that is a proper call and maybe luck if it worked the way you wanted.
RoyceP
Postby RoyceP » Sat Jul 22, 2017 7:24 pm
io_mux_reg.h, beginning at line 115, through at least line 131, suggest to me that the call is proper.
Users browsing this forum: No registered users and 71 guests
