ILI9341 not working
ILI9341 not working
Hi everyone,
I have spent the last two weeks on trying to use the ILI9341 SPI display.
Neither the Loboris TFT driver nor other works. They all work perfectly on ESP Wrover kit, but do not work on ESP32 Wroom kit. I tried different pin configuration and changed the code, but none of them worked.
Does anyone has a tested driver on ILI9341 display? I ordered 4 displays like this one, it works on none of them.
https://www.amazon.fr/Hiletgo-%C3%A9cra ... ds=ili9341
Thank you for your help.
Re: ILI9341 not working
I've tested the library on a similar board (only with touch panel) and there was no problem.
Can you be more specific about what exactly does not work?
You have to connect +5V to display's Vcc or to short the jumper J1 and connect Vcc to +3.3V.
Of course, you also have to connect LED pin to +5V.
I am also trying to hook-up my Esp32 to the ILI9341
I am trying to build and flash the ESP32_TFT_library to my ESP32, but i am getting the same error over and over. (i am on windows 10 and using Mingw32). I have the latest version of the esp-idf from git and also your latests update of the ESP32_TFT_library. Why am i getting this error and how to fix this?
- 171025_error_message.png (91.51 KiB) Viewed 34326 times
Hi Loboris,
Thank you for your answer. In fact it was just that I had not pulled the reset pin to +3.3V. Now it works.
Currently my problem is driving the ESP23S17. Do you have a library for this SPI chip?
Thank you,
Damian
Thank you,
Damian
It is caused by the latest changes in esp-idf.Zwegogo wrote: I am also trying to hook-up my Esp32 to the ILI9341
For now, just comment the line 836 in components/spiffs/spiffs_vfs.c
The fix will be pushed soon (I'm working on some other changes too).
I've never heard of ESP23S17 and can't find any info on it.damian_py wrote:Hi Loboris,
Thank you,
Damian
loboris wrote:It is caused by the latest changes in esp-idf.Zwegogo wrote: I am also trying to hook-up my Esp32 to the ILI9341
Thank you Loboris, that did the trick!
Sorry, I was thinking about MCP23S17 by microchip, the SPI equivalent of the MCP23017.
http://ww1.microchip.com/downloads/en/D ... 01952C.pdf
Hi Loboris,
I am trying to combine the SD card example code (included in the esp-idf) with the ili9341 TFT library to display my images to the screen from the SD-card. I had the SD card example working both in SPI mode and SDMMC mode, but want to use the SPI mode, because it takes up less connections and components for my final setup. I have searched, but haven't found an example anywhere that combines your tft library with an SD-card. So therefore i wanted to combine the code myself. When i want to make all , i get the error messages below, saying that the SPI libaries of the sd_card example collide with the SPI_loboris libaries of the TFT. What can i do to fix this? Or is there another way to use an SD-card with your library so I can load the images from the SD-card on to the TFT screen?
Regards,
Stefan
$ make app
CC build/main/main.o
In file included from C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_master.h:23:0,
from C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/sdspi_host.h:22,
from C:/msys32/home/stefan/esp/esp-idf/components/fatfs/src/esp_vfs_fat.h:21,
from C:/msys32/home/stefan/esp/sns_proto/main/sd_card.h:15,
from C:/msys32/home/stefan/esp/sns_proto/main/main.c:36:
C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_common.h:40:5: error: redeclaration of en umerator 'SPI_HOST'
SPI_HOST=0, ///< SPI1, SPI
In file included from C:/msys32/home/stefan/esp/sns_proto/components/tft/tftspi.h:11:0,
from C:/msys32/home/stefan/esp/sns_proto/main/images_1.h:25,
from C:/msys32/home/stefan/esp/sns_proto/main/main.c:35:
C:/msys32/home/stefan/esp/sns_proto/components/spidriver/spi_master_lobo.h:42:5: note: previous definition of 'S PI_HOST' was here
SPI_HOST=0, ///< SPI1, SPI; Cannot be used in this driver!
C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_common.h:41:5: error: redeclaration of en umerator 'HSPI_HOST'
HSPI_HOST=1, ///< SPI2, HSPI
C:/msys32/home/stefan/esp/sns_proto/components/spidriver/spi_master_lobo.h:43:5: note: previous definition of 'H SPI_HOST' was here
C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_common.h:42:5: error: redeclaration of en umerator 'VSPI_HOST'
VSPI_HOST=2 ///< SPI3, VSPI
C:/msys32/home/stefan/esp/sns_proto/components/spidriver/spi_master_lobo.h:44:5: note: previous definition of 'V SPI_HOST' was here
In file included from C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/sdspi_host.h:22:0,
C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_master.h:33:0: warning: "SPI_DEVICE_BIT_L SBFIRST" redefined
#define SPI_DEVICE_BIT_LSBFIRST (SPI_DEVICE_TXBIT_LSBFIRST|SPI_DEVICE_RXBIT_LSBFIRST); ///< Transmit and receive LSB first
C:/msys32/home/stefan/esp/sns_proto/components/spidriver/spi_master_lobo.h:67:0: note: this is the location of t he previous definition
#define SPI_DEVICE_BIT_LSBFIRST (SPI_TXBIT_LSBFIRST|SPI_RXBIT_LSBFIRST); ///< Transmit and receive L SB first
C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_master.h:41:15: error: conflicting types for 'transaction_cb_t'
typedef void(*transaction_cb_t)(spi_transaction_t *trans);
C:/msys32/home/stefan/esp/sns_proto/components/spidriver/spi_master_lobo.h:76:15: note: previous declaration of 'transaction_cb_t' was here
typedef void(*transaction_cb_t)(spi_lobo_transaction_t *trans);
C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_master.h:65:0: warning: "SPI_TRANS_MODE_D IOQIO_ADDR" redefined
#define SPI_TRANS_MODE_DIOQIO_ADDR (1<<4) ///< Also transmit address in mode selected by SPI_MODE_DIO/SPI_M ODE_QIO
C:/msys32/home/stefan/esp/sns_proto/components/spidriver/spi_master_lobo.h:101:0: note: this is the location of the previous definition
#define SPI_TRANS_MODE_DIOQIO_ADDR (1<<2) ///< Also transmit address in mode selected by SPI_MODE_DIO/SPI_M ODE_QIO
C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_master.h:66:0: warning: "SPI_TRANS_USE_RX DATA" redefined
#define SPI_TRANS_USE_RXDATA (1<<2) ///< Receive into rx_data member of spi_transaction_t instead int o memory at rx_buffer.
C:/msys32/home/stefan/esp/sns_proto/components/spidriver/spi_master_lobo.h:102:0: note: this is the location of the previous definition
#define SPI_TRANS_USE_RXDATA (1<<3) ///< Receive into rx_data member of spi_lobo_transaction_t instea d into memory at rx_buffer.
C:/msys32/home/stefan/esp/esp-idf/components/driver/include/driver/spi_master.h:67:0: warning: "SPI_TRANS_USE_TX DATA" redefined
#define SPI_TRANS_USE_TXDATA (1<<3) ///< Transmit tx_data member of spi_transaction_t instead of data at tx_buffer. Do not set tx_buffer when using this.
C:/msys32/home/stefan/esp/sns_proto/components/spidriver/spi_master_lobo.h:103:0: note: this is the location of the previous definition
#define SPI_TRANS_USE_TXDATA (1<<4) ///< Transmit tx_data member of spi_lobo_transaction_t instead of data at tx_buffer. Do not set tx_buffer when using this.
In file included from C:/msys32/home/stefan/esp/esp-idf/components/bt/bluedroid/include/bt_target.h:1829:0,
from C:/msys32/home/stefan/esp/esp-idf/components/bt/bluedroid/bta/include/bta_api.h:28,
from C:/msys32/home/stefan/esp/sns_proto/main/main.c:26:
C:/msys32/home/stefan/esp/esp-idf/components/bt/bluedroid/include/bt_trace.h:28:14: error: expected identifier o r '(' before string constant
#define TAG "BT"
C:/msys32/home/stefan/esp/sns_proto/main/sd_card.h:20:20: note: in expansion of macro 'TAG'
static const char *TAG = "example";
C:/msys32/home/stefan/esp/sns_proto/main/main.c: In function 'app_main':
C:/msys32/home/stefan/esp/sns_proto/main/main.c:177:35: error: 'card' undeclared (first use in this function)
sdmmc_card_print_info(stdout, card);
C:/msys32/home/stefan/esp/sns_proto/main/main.c:177:35: note: each undeclared identifier is reported only once f or each function it appears in
C:/msys32/home/stefan/esp/sns_proto/main/main.c:153:38: warning: unused variable 'mount_config' [-Wunused-variab le]
esp_vfs_fat_sdmmc_mount_config_t mount_config = {
C:/msys32/home/stefan/esp/sns_proto/main/main.c:141:25: warning: variable 'slot_config' set but not used [-Wunus ed-but-set-variable]
sdspi_slot_config_t slot_config = SDSPI_SLOT_CONFIG_DEFAULT();
C:/msys32/home/stefan/esp/sns_proto/main/main.c:139:18: warning: unused variable 'host' [-Wunused-variable]
sdmmc_host_t host = SDSPI_HOST_DEFAULT();
make[1]: *** [/home/stefan/esp/esp-idf/make/component_wrapper.mk:243: main.o] Error 1
make: *** [C:/msys32/home/stefan/esp/esp-idf/make/project.mk:434: component-main-build] Error 2
Regards,
Stefan
$ make app
#define TAG "BT"
Thank you for reporting the issue, I'll check it and try to fix it.Zwegogo wrote:Hi Loboris,
Regards,
Stefan
Users browsing this forum: No registered users and 96 guests
