Using Node.js and Noble for BLE partners
kolban
Postby kolban » Sat Dec 02, 2017 7:55 pm
I'm a big fan of BLE on the ESP32 and have been using nRFConnect for my BLE testing. However I needed more than I can manually tinker with on my phone. I needed to run scripts, soak tests and more ... so I needed to write code than runs on my PC that communicate with the ESP32 through BLE. There are APIs for Windows, Linux and Mac ... but I'm pretty keen on interpreted languages for scripting tests and wanted something portable. Then I found Noble and Bleno:
https://github.com/sandeepmistry/noble
https://github.com/sandeepmistry/bleno
These are pretty darn good libraries for Node.js (JavaScript) that allow me to write BLE clients and servers that run on my PC (Windows or Linux) that can interact with an ESP32. The documentation isn't brilliant so I'm writing up some guides that suit me ... however the documentation is just about usable.
Here is a sample app that finds my ESP32 device, retrieves a service, retrieves a characteristic, reads the current value of the characteristic and writes a new one.
var noble = require("noble");
const name = "MYDEVICE";
const ESP32_SERVICE        = "4fafc2001fb5459e8fccc5c9c331914b";
const ESP32_CHARACTERISTIC = "4fafc2011fb5459e8fccc5c9c331914b";
noble.on("discover", function(peripheral) {
   if (peripheral.advertisement.localName == name ) {
      noble.stopScanning();
      peripheral.connect((error) => {
         peripheral.discoverServices([ESP32_SERVICE], (error, services) => {
            if (services.length > 0) {
               services[0].discoverCharacteristics([ESP32_CHARACTERISTIC], (error, characteristics) => {
                  if (characteristics.length > 0) {
                     var characteristic = characteristics[0];
                     characteristic.read((error, data) => {
                        console.log("Here is the current value: " + data);
                        var newValue = "Hello world: " + new Date().getTime();
                        console.log("Changing to: " + newValue);
                        characteristic.write(Buffer.from(newValue));
                        peripheral.disconnect();
noble.on("stateChange", function(state) {
   if (state == "poweredOn") {
      noble.startScanning();
While it might look scary if you don't read JavaScript, the Noble and Bleno libraries are really quite well architected and easy to consume.
I wanted to pass this on in case you needed BLE interactions/testing from your PC <-> ESP32.
fly135
Re: Using Node.js and Noble for BLE partners
Postby fly135 » Sat Feb 17, 2018 10:00 pm
Just happened to see this. Going to give it a try. Thanks for posting!
Petaroo
Postby Petaroo » Thu Oct 19, 2023 9:43 am
That looks awesome. I will try that! May I ask for advice? I tried on Ubuntu 22.04 LTE, VScode. NodeJS looked fine to me, however, I could not get started with the 'noble' library. I always got the error "Uncaught Error Error: Module did not self-register". All website recommendations to fix that error did not work out.
Which IDE would you recommend for the setup: Ubuntu 22.04 LTE, VScode. NodeJS, noble?
Thanks heaps in advance.
Users browsing this forum: No registered users and 31 guests
