Help needed! ESP32-Alexa (A.I.) client
mano1979
Postby mano1979 » Sat Feb 24, 2018 3:02 am
In this project i found on github https://github.com/MrBuddyCasino/ESP32_Alexa, there should be a function that sends a "ping" every 5 minutes to the server it is connected to (amazon's alexa server), to keep the connection alive and avoid the esp32 from beeing reset. This is not implemented yet.
In the esp32-alexa code, preparations are made to implement this function, though the writer has no time anymore and is not able to help out. This is what he wrote:
I changed the programming model from threaded to async, as I needed to reclaim the stack memory. See components/asio/asio_http2.c.
full conversation here:https://github.com/MrBuddyCasino/ESP32_Alexa/issues/13
I am not a great programmer and have no knowledge of the esp32-idf language. I tried some things here and there, but it always results in a broken script that won't compile or work.
I hope someone here is able and willing to lend a hand.
mano1979
Re: Help needed! ESP32-Alexa (A.I.) client
Postby mano1979 » Tue Feb 27, 2018 8:30 pm
Some additional links with code examples. I just don't know how to implement it.
ESP-idf Ping example (incl delay): viewtopic.php?
Alexa Voice Service Ping-Setup: https://developer.amazon.com/docs/alexa
Trialblazer47
Postby Trialblazer47 » Sun Jul 15, 2018 10:12 am
Hi looks like the links are lost.. could you please help find those links. I also need to know the process.
Thanks.
Users browsing this forum: No registered users and 114 guests
