If you are into ARM programming and your device has support for SWD you can now do it over wifi with the ESP32!
https://github.com/Ebiroll/esp32_blackmagic
I wanted to send it back as a pull request to, https://github.com/blacksphere/blackmagic
but do not have the skills to fix the makefiles.
This is better than i.e. ST-LINK as you can flash and debug your device without using any USB-port.
/Olof
ARM single wire debug with black magic and the ESP32
Re: ARM single wire debug with black magic and the ESP32
Nice! Had some trouble flashing BMP to a Blue Pill due to 64k flash limit, this would have saved me some time. Is the port feature complete?
Its almost complete, except for Jtag. You must use the SWD pins. 2 of them + ground.
I am currently adding a web based log viewer/serial terminal. Wanted to use the SWO pin for that but will probably just use an extra UART instead. It seems easier to understand.
I am amazed how well it works. It feels like black magic.
I know this code is quite old now, and I am trying to reach you on github as well - is there a chance you can update it for modern platformio / ESPIDF? It's not working on PIO 6.1.9
Sorry for late reply, I have updated the repository now and now it compiles and I also merged the latest black magic code.
As well as support for the esp32-c3 over JTAG. This has not been tested however.
Users browsing this forum: No registered users and 122 guests
