What is the purpose of two OTA partition?
Re: What is the purpose of two OTA partition?
My custom partition is not working
# Name, Type, SubType, Offset, Size
nvs, data, nvs, 0x9000, 0x4000
otadata, data, ota, 0xd000, 0x2000
phy_init, data, phy, 0xf000, 0x1000
ota_0, app, ota_0, 0x10000, 0x177000
ota_1, app, ota_1, , 0x177000
storage, data, fat, ,1M
any idea why?
any idea why?
In what way is it "not working"?
No debug output.
But this custom partition works. It uses factory . previous one uses two OTA. any idea why?. I want to avoid wasting my space. I need each OTA about 1.5M
factory, app, factory, 0x10000, 0x1f0000
It could be due to alignment issue
This works.
but this does not. different size.
This works.
See the following.
http://esp-idf.readthedocs.io/en/latest ... ffset-size
It reads:
It reads:
App partitions have to be at offsets aligned to 0x10000 (64K). If you leave the offset field blank, the tool will automatically align the partition. If you specify an unaligned offset for an app partition, the tool will return an error.
ok, Alignment applies to offset only not size. which is same and correct on all three examples.
This works
but this does not
ota_0, app, ota_0, 0x10000, 0x1f0000
ota_1, app, ota_1, , 0x1f0000
any idea why not.
with no storage this also works.
This works
but this does not
any idea why not.
The one that doesn't work exceeds 4MB of flash. That's all I can see that might be an issue.snahmad75 wrote:ok, Alignment applies to offset only not size. which is same and correct on all three examples.
John A
Sounds like a good idea to me. I don't see why it should be any less reliable than using two OTA partitions.robpelu wrote:And now the question... do you see some danger in this approach, one that I couldn't see until now ?
The only one I see is that the update process failing to write somewhere in the OTA partition and then not possible to boot that one, but the factory firmware will keep executing to update again, and at some point it should succeed.
John A
Users browsing this forum: No registered users and 256 guests
