What is the purpose of two OTA partition?
snahmad75
Re: What is the purpose of two OTA partition?
Postby snahmad75 » Tue May 08, 2018 2:11 pm
My custom partition is not working
# Name, Type, SubType, Offset, Size
nvs, data, nvs, 0x9000, 0x4000
otadata, data, ota, 0xd000, 0x2000
phy_init, data, phy, 0xf000, 0x1000
ota_0, app, ota_0, 0x10000, 0x177000
ota_1, app, ota_1, , 0x177000
storage, data, fat, ,1M
any idea why?
kolban
Postby kolban » Tue May 08, 2018 2:15 pm
In what way is it "not working"?
snahmad75
Postby snahmad75 » Tue May 08, 2018 2:20 pm
No debug output.
snahmad75
Postby snahmad75 » Tue May 08, 2018 2:25 pm
But this custom partition works. It uses factory . previous one uses two OTA. any idea why?. I want to avoid wasting my space. I need each OTA about 1.5M
factory, app, factory, 0x10000, 0x1f0000
snahmad75
Postby snahmad75 » Tue May 08, 2018 2:32 pm
snahmad75
Postby snahmad75 » Tue May 08, 2018 3:12 pm
It could be due to alignment issue
This works.
but this does not. different size.
kolban
Postby kolban » Tue May 08, 2018 4:03 pm
See the following.
http://esp-idf.readthedocs.io/en/latest ... ffset-size
It reads:
App partitions have to be at offsets aligned to 0x10000 (64K). If you leave the offset field blank, the tool will automatically align the partition. If you specify an unaligned offset for an app partition, the tool will return an error.
snahmad75
Postby snahmad75 » Tue May 08, 2018 5:12 pm
ok, Alignment applies to offset only not size. which is same and correct on all three examples.
This works
but this does not
ota_0, app, ota_0, 0x10000, 0x1f0000
ota_1, app, ota_1, , 0x1f0000
any idea why not.
with no storage this also works.
fly135
Postby fly135 » Tue May 08, 2018 6:30 pm
snahmad75 wrote:ok, Alignment applies to offset only not size. which is same and correct on all three examples.
The one that doesn't work exceeds 4MB of flash. That's all I can see that might be an issue.
John A
fly135
Postby fly135 » Tue May 08, 2018 6:32 pm
robpelu wrote:And now the question... do you see some danger in this approach, one that I couldn't see until now ?
The only one I see is that the update process failing to write somewhere in the OTA partition and then not possible to boot that one, but the factory firmware will keep executing to update again, and at some point it should succeed.
Sounds like a good idea to me. I don't see why it should be any less reliable than using two OTA partitions.
John A
Users browsing this forum: No registered users and 115 guests
