Hello all!
I am pretty new with esp32 an c++ in general and your input would be greately appreciated.
I have a chunk of code where the goal is to send strings of data using a connection that were first invoked.
For this nodemcu-32s was used.
https://gitlab.com/toniVarga/polymorphism
Can you please advise me is this the right way to do it or is there a better way, or correct way.
So basically there is base class MyComm with pure virtual function and BT and UART classes that inhert from MyComm.
In setup we chose where to send the strings based on connection in which the first byte was received.
Also could you please advise me on some tools for debugging and tracing stack or heap level and stuff like that.
Polymorphism Code Review
Re: Polymorphism Code Review
You got the basic usage of inheritance and virtual methods right. There is one nasty bug though - you forgot to make your destructor virtual in the base class (MyComms). This means that if you ever destroyed an object through a pointer to the base class, the correct destructor would not be called.
Another useful thing is to use override on all overriden methods:
Like this the compiler will warn you if the method doesn't correspond with any virtual from the base class. This can happen because of misspelling or renaming the method in the base class. It's just good practice.
One other hint - unrelated to inheritance - is to make the parameter of println a const reference. This will avoid unnecessary copies and allocations which for an arduino are pretty significant.
class MyComm
public:
//MyComm(); //no need for a constructor
virtual ~MyComm() = default; //cannot make this abstract
virtual void println(String) = 0;
class BT: public MyComm
void println(String) override;
virtual void println(const String&) = 0;
Thanks very much for explanations!
Users browsing this forum: No registered users and 70 guests
