Very wrong pin usage in ESP32 SPI Slave examples.
AndreiC
Postby AndreiC » Thu Aug 09, 2018 7:47 pm
This one cost me about 3 hours today:
In the README.md file for the SPI slave examples, as well as in the example code, there is:
Please run wires between the following GPIOs between the slave and master to make the example function:
Signal	Slave	Master
Handshake	GPIO2	GPIO2
MOSI	GPIO12	GPIO12
MISO	GPIO13	GPIO13
SCLK	GPIO15	GPIO15
CS	GPIO14	GPIO14
According to the reference manual, module diagrams, and running code, MOSI and MISO are reversed, as are SCLK and CS.
The proper settings are:
MOSI GPIO13
MISO GPIO12
SCK GPIO14
CS GPIO15
Andrei
kolban
Re: Very wrong pin usage in ESP32 SPI Slave examples.
Postby kolban » Thu Aug 09, 2018 9:56 pm
Howdy Andrei,
Can you elaborate ... I looked at the code but am not seeing what you are seeing. I think you are saying that
MOSI is 13
MISO is 12
while the documentation is saying
MOSI is 12
MISO is 13
But yet when I read here:
https://github.com/espressif/esp-idf/bl ... app_main.c
and
it sure does feel like MOSI is 12 and MISO is 13.
Return to “Sample Code”
