Use RMII in ESP32-WROOM-32U
alpesh_borad
Postby alpesh_borad » Sat Sep 15, 2018 8:34 am
I am using RMII mode in ESP32-WROOM-32U using KSZ8041RNL.
According to KSZ8041RNL datasheet, it will give 50MHz clock output which will given to MAC (ESP32-WROOM-32U).
So here how i will connect to MAC (Pin#)?
Regards,
Alpesh.
WiFive
Re: Use RMII in ESP32-WROOM-32U
Postby WiFive » Sat Sep 15, 2018 11:25 pm
alpesh_borad
Postby alpesh_borad » Mon Sep 17, 2018 5:14 am
Thank you very much for the Answer.
What is the value of Pull up resistor on GPIO0 using as EMAC_TX_CLK.
Have you any reference schematic?
Please provide if you have.
Regards,
Alpesh.
DerSpatz
Postby DerSpatz » Tue Sep 18, 2018 4:33 am
Return to “Hardware”
