Issue sending data to browser using AT commands and TCP server
Quagmire
Postby Quagmire » Wed Aug 15, 2018 1:40 pm
I am attempting to create a TCP server on the ESP32 in order to connect to a browser page, which will allow users to enter their local WiFi SSID and password, along with some other program specific information.
I have followed the example commands in the ESP32 AT Instruction Set pdf...specifically, those on pages 73-75 for setting up a TCP server.
The issue that I have is that once a request has been made from the browser (Chrome Version 68.0.3440.106, 64 bit, running on Windows 7) to IP address 192.168.4.1, the ESP32 reports a connection, but then I cannot send information back to the browser...none of the AT+CIPSEND commands will allow it...they all report "ERROR"...I tried every version of them for both links 0 and 1. Eventually, the connection times out and is closed automatically.
Below is the command set that I entered via a terminal emulator. If anyone can give me suggestions or advise me as to where the issue is, I would appreciate it!!
AT+RESTORE
1,CLOSED
0,CLOSED
OK
ready
AT+GMR
AT version:1.2.0.0-dev(c3c7f6f - Jun 20 2018 07:40:00)
SDK version:v3.1-dev-1381-g9a55b42f
compile time:Jun 26 2018 14:02:43
OK
AT+CWSAP="MyESP32SSID","MyPassword",5,3,5,0
OK
AT+CWMODE=3
OK
AT+CIPMUX=1
OK
AT+CIPSERVER=1,80
OK
AT+CIPSTO=1000
OK
AT+CIPDINFO=1
OK
+IPD,0,405,192.168.4.2,49519:GET / HTTP/1.1
Host: 192.168.4.1
Connection: keep-alive
Cache-Control: max-age=0
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.9
0,CONNECT
1,CONNECT
AT+CWLIF
+CWLIF:192.168.4.2,xx:xx:xx:xx:xx:xx //Note: I replaced the MAC address with x's
OK
AT+CIPSTATUS
STATUS:3
+CIPSTATUS:0,"TCP","192.168.4.2",49519,80,1
+CIPSTATUS:1,"TCP","192.168.4.2",49520,80,1
OK
AT+CIFSR
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"xx:xx:xx:xx:xx:xx" //Note: I replaced the MAC address with x's
+CIFSR:STAIP,"0.0.0.0"
+CIFSR:STAMAC,"xx:xx:xx:xx:xx:xx" //Note: I replaced the MAC address with x's
OK
AT+CIPSEND=0,4
ERROR
AT+CIPSENDEX=0,4
ERROR
AT+CIPSEND=4
ERROR
AT+CIPSENDEX=4
ERROR
AT+CIPSEND=1,4,"192.168.4.2",49520
ERROR
AT+CIPSENDEX=1,4,"192.168.4.2",49520
ERROR
AT+CIPSEND=0,4,"192.168.4.2",49519
ERROR
AT+CIPSENDEX=0,4,"192.168.4.2",49519
ERROR
AT+CIPSEND=1,4
ERROR
AT+CIPSENDEX=1,4
ERROR
1,CLOSED
danmcc22
Re: Issue sending data to browser using AT commands and TCP server
Postby danmcc22 » Sun Sep 16, 2018 4:51 am
I'm new this myself but a do see a problem in your CIFSR response being "+CIFSR:STAIP,"0.0.0.0". You don't have an IP address.
Try AT+CWJAP=.... instead of AT+CWSAP=.... CWSAP configures YOUR softAP. Hope this helps.
Users browsing this forum: No registered users and 100 guests
