I'm designing a board with the ESP32.
I noticed that in the latest hardware guideline, I mean the version V 2.4, the matching network changed.
At chapter "2.1.5 RF" the document says:
"A PI-type matching network is essential for antenna matching in the circuit design.
C-L-C structure is recommended for the matching network."
That network has no decoupling capacitor between the antenna and the LNA_IN pin of the ESP32.
I've always seen one decoupling capacitor between antennas and RF chips.
The typical value of this capacitor is just a few pF and it does not alter the matching network.
QUESTION 1
Are you guys aware that between the antenna and the ESP32 there isn't the decoupling capacitor?
QUESTION 2
Have you ever tested C-L-C structure on the ESP32?
QUESTION 3
All ESP32 modules have a matching network that is not a C-L-C PI-type network.
Why did you change the topology of the matching network after years of well established C-C-L topology.
Thanks,
Enrico Migliore
Antenna matching network question
Re: Antenna matching network question
The newer modules wrover-b and wroom-32d/u and pico use C-L-Cwwwenrico wrote:
QUESTION 2
QUESTION 3
thank you for the answer.
DECOUPLING CAPACITOR
Are you aware that the antenna and the LNA input pin are not galvanic isolated?
thank you,
Enrico Migliore
thank you,
Enrico Migliore
Users browsing this forum: No registered users and 161 guests
