I have problems connecting to a remote server.
In one project my code works flawlessly, in the other the connect() call brings an ECONNABORTED error.
What can be the reason for a ECONNABORTED?
Thank you!
Best,
Malte
Getting ECONNABORTED when trying to connect()
Re: Getting ECONNABORTED when trying to connect()
the connect() call takes quite a time.
Before it returns an error I get this line in the log:
- I (16465) wifi: pm start, type:0
- I (7304) HTTP: created socket with socket_id = 0x2
I (7405) HTTP: socket_id = 0x2
I (7405) HTTP: connect()...
E (24905) HTTP: Connect to server failed! errno=113
E (24905) HTTP: Connect to http server failed!
E (24905) HTTP: Exiting task due to fatal error...
I have updated to the latest esp-idf SDK.
The problem disappeared.
Thanks.
Thanks.
I'm also really struggeling with this but unfortunately an update of the ESP-IDF did not help (using current master already). The problem turned out to be the firewall of my own laptop. I had written a simple echo server in and when I ran the server on my Raspberry Pi it worked flawlessly. Maybe that helps someone.
cheers,
rizzir
cheers,
rizzir
Did u try setting the receiving port correctly? i was having the same issue..
1) i disabled all the firewalls
2) changed the receiving port to 80 (http) instead of default 21
hope this helps
Best Regards,
Sumesh
hope this helps
Best Regards,
Sumesh
Hi,MalteJ wrote:I have updated to the latest esp-idf SDK.
Thanks.
We are using ESP32 IDF 2.1 Stable Release for our product development purpose and we are facing same issue which you have mentioned into earlier posts like below
So, In which ESP32 SDK, you were tested and which is working fine without any issue? so that we will check same into that SDK as well.I (7304) HTTP: created socket with socket_id = 0x2
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi ESP_Angus or WiFive or SDK Developer,
Would you please check my last post into this topic as we are also facing this type of issue while using ESP32 IDF 2.1 in our product development purpose?
Are you sure that issue has been fixed into ESP32 IDF 3.0 or 3.1 Stable Release if it is really issue of IDF or Stack itself?
Let me know if need anything else from my side regarding this issue
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi ESP_Angus and SDK Developers,
We have enabled debug logs of LWIP and TCP and found that maximum SYNC retries have been reached. SO, Do you have any idea or any clue for this type of issue?
[11:04:26.727]tcp_close: closing in State: ESTABLISHED
[11:04:26.727]tcp_slowtmr: processing active pcb
[11:04:26.836]tcp_slowtmr: processing active pcb
[11:04:26.836]tcp_slowtmr: polling application
[11:04:27.326]tcp_slowtmr: polling application
[11:04:27.326]tcp_slowtmr: processing active pcb
[11:04:27.816]tcp_slowtmr: processing active pcb
[11:04:27.816]tcp_slowtmr: polling application
[11:04:28.306]tcp_slowtmr: polling application
[11:04:28.306]tcp_slowtmr: processing active pcb
[11:04:28.791]tcp_slowtmr: processing active pcb
[11:04:28.791]tcp_slowtmr: polling application
[11:04:29.286]tcp_slowtmr: polling application
[11:04:29.286]tcp_slowtmr: processing active pcb
[11:04:29.776]tcp_slowtmr: processing active pcb
[11:04:29.776]tcp_slowtmr: polling application
[11:04:30.265]tcp_slowtmr: polling application
[11:04:30.265]tcp_slowtmr: processing active pcb
[11:04:30.756]tcp_slowtmr: processing active pcb
[11:04:30.756]tcp_slowtmr: polling application
[11:04:31.246]tcp_slowtmr: polling application
[11:04:31.246]tcp_slowtmr: processing active pcb
[11:04:31.731]tcp_slowtmr: processing active pcb
[11:04:31.731]tcp_slowtmr: polling application
[11:04:32.226]tcp_slowtmr: polling application
[11:04:32.226]tcp_slowtmr: processing active pcb
[11:04:32.715]tcp_slowtmr: processing active pcb
[11:04:32.715]tcp_slowtmr: polling application
[11:04:33.205]tcp_slowtmr: polling application
[11:04:33.205]tcp_slowtmr: processing active pcb
[11:04:33.696]tcp_slowtmr: processing active pcb
[11:04:33.696]tcp_slowtmr: polling application
[11:04:34.186]tcp_slowtmr: polling application
[11:04:34.186]tcp_slowtmr: processing active pcb
[11:04:34.671]tcp_slowtmr: processing active pcb
[11:04:34.671]tcp_slowtmr: polling application
[11:04:35.166]tcp_slowtmr: polling application
[11:04:35.166]tcp_slowtmr: processing active pcb
[11:04:35.655]tcp_slowtmr: processing active pcb
[11:04:35.655]tcp_slowtmr: polling application
[11:04:36.145]tcp_slowtmr: polling application
[11:04:36.145]tcp_slowtmr: processing active pcb
[11:04:36.636]tcp_slowtmr: processing active pcb
[11:04:36.636]tcp_slowtmr: polling application
[11:04:37.125]tcp_slowtmr: polling application
[11:04:37.125]tcp_slowtmr: processing active pcb
[11:04:37.616]tcp_slowtmr: processing active pcb
[11:04:37.616]tcp_slowtmr: polling application
[11:04:38.106]tcp_slowtmr: polling application
[11:04:38.106]tcp_slowtmr: processing active pcb
[11:04:38.595]tcp_slowtmr: processing active pcb
[11:04:38.595]tcp_slowtmr: polling application
[11:04:39.085]tcp_slowtmr: polling application
[11:04:39.085]tcp_slowtmr: processing active pcb
[11:04:39.582]tcp_slowtmr: processing active pcb
[11:04:39.582]tcp_slowtmr: polling application
[11:04:40.065]tcp_slowtmr: polling application
[11:04:40.065]tcp_slowtmr: processing active pcb
[11:04:40.556]tcp_slowtmr: processing active pcb
[11:04:40.556]tcp_slowtmr: polling application
[11:04:41.046]tcp_slowtmr: polling application
[11:04:41.046]tcp_slowtmr: processing active pcb
[11:04:41.535]tcp_slowtmr: processing active pcb
[11:04:41.535]tcp_slowtmr: polling application
[11:04:42.025]tcp_slowtmr: polling application
[11:04:42.025]tcp_slowtmr: processing active pcb
[11:04:42.519]tcp_slowtmr: processing active pcb
[11:04:42.519]tcp_slowtmr: polling application
[11:04:43.006]tcp_slowtmr: polling application
[11:04:43.006]tcp_slowtmr: processing active pcb
[11:04:43.491]tcp_slowtmr: processing active pcb
[11:04:43.491]tcp_slowtmr: polling application
[11:04:43.985]tcp_slowtmr: polling application
[11:04:43.985]tcp_slowtmr: processing active pcb
[11:04:44.497]tcp_slowtmr: max SYN retries reached
[11:04:44.497]tcp_pcb_purge
[11:04:44.497]tcp_pcb_purge: data left on ->unacked
[11:04:44.497]tcp_slowtmr: processing active pcb
[11:04:44.497]tcp_slowtmr: polling application
[11:04:44.497][FirmWareDownLoad.c ConnectToSocket 298] : ... socket connect failed errno=113
[11:04:44.497][FirmWareDownLoad.c GetFirmware 682] : failed to connect to socket : urlvar.socket = 4
[11:04:44.497][FirmWareDownLoad.c GetFirmware 686] : Socket Connection fail
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi Espressif System SDK Developers,
Is there any update regarding this issue or not?
Regards,
Ritesh Prajapati
Ritesh Prajapati
I can't help but wonder why you don't try building with the latest stable release and check the results yourself. I am able to communicate with HTTP servers just fine with v3.1.
Users browsing this forum: No registered users and 105 guests
