Heap memory consumption in webserver example
burkulesomesh43
Postby burkulesomesh43 » Sun Oct 21, 2018 8:09 pm
I am using webserver example.
this example takes lot of heap memory. In the webserver task I am diaplaying free heap memory. as I hit the ip on browser, the web page gets opened but there is lot of heap memory consumption during task execution maybe due to my html code which is am hitting as my web page.
so How to solve this heap memory consumption in my task??
static void web_server(void *pvParameters)
  struct netconn *conn, *newconn;
  err_t err;
  conn = netconn_new(NETCONN_TCP);
  netconn_bind(conn, NULL, 80);
  netconn_listen(conn);
  do {
     err = netconn_accept(conn, &newconn);
     if (err == ERR_OK) {
    	 vTaskDelay(10);
       http_server_netconn_serve(newconn);
       netconn_delete(newconn);
     ESP_LOGI("ss", "MALLOC_CAP_DEFAULT %d", heap_caps_get_free_size(MALLOC_CAP_DEFAULT));
   } while(err == ERR_OK);
   netconn_close(conn);
   netconn_delete(conn);
   vTaskDelete(NULL);
Somesh Burkule
ESP_Angus
Re: Heap memory consumption in webserver example
Postby ESP_Angus » Mon Oct 22, 2018 3:53 am
burkulesomesh43 wrote: this example takes lot of heap memory. In the webserver task I am diaplaying free heap memory. as I hit the ip on browser, the web page gets opened but there is lot of heap memory consumption during task execution maybe due to my html code which is am hitting as my web page.
Can you give some indication of how much memory is being used? WiFi & TCP/IP stack will use some memory for buffers while connections are active.
burkulesomesh43
Postby burkulesomesh43 » Mon Oct 22, 2018 5:42 am
ESP_Angus wrote:Hi,
[0;32mI (118045) ss: MALLOC_CAP_DEFAULT 75696[0m
[0;32mI (122705) ss: MALLOC_CAP_DEFAULT 62420[0m
[0;32mI (184475) ss: MALLOC_CAP_DEFAULT 49644[0m
[0;32mI (189135) ss: MALLOC_CAP_DEFAULT 34888[0m
Somesh Burkule
ESP_Angus
Postby ESP_Angus » Mon Oct 22, 2018 6:42 am
Does the free memory go back up or is it permanently going down?
Are you using the http_server example or some other code? Can you post the code you're running somewhere?
burkulesomesh43
Postby burkulesomesh43 » Mon Oct 22, 2018 7:59 am
ESP_Angus wrote:Does the free memory go back up or is it permanently going down?
it is permenetly going down. sorry I can't upload code.
I am using this function in http_server_netconn_serve(newconn).
char *replaceWord(const char *s, const char *oldW,const char *newW)
    char *result;
    int i, cnt = 0;
    int newWlen = strlen(newW);
    int oldWlen = strlen(oldW);
    // Counting the number of times old word
    // occur in the string
    for (i = 0; s[i] != '\0'; i++)
        if (strstr(&s[i], oldW) == &s[i])
            cnt++;
            // Jumping to index after the old word.
            i += oldWlen - 1;
    // Making new string of enough length
    result = (char *)malloc(i + cnt * (newWlen - oldWlen) + 1);
    i = 0;
    while (*s)
        // compare the substring with the result
        if (strstr(s, oldW) == s)
            strcpy(&result[i], newW);
            i += newWlen;
            s += oldWlen;
        else
            result[i++] = *s++;
    result[i] = '\0';
    return result;
Somesh Burkule
loboris
Postby loboris » Mon Oct 22, 2018 1:52 pm
Do you free somewhere the memory allocated in replaceWord() ?
How can you excpect help if you cannot give the whole code causing the issue?
burkulesomesh43
Postby burkulesomesh43 » Mon Oct 22, 2018 4:56 pm
loboris wrote:Do you free somewhere the memory allocated in replaceWord() ?
issue solved. the memory allocated in replaceWord() is freed.
Somesh Burkule
Users browsing this forum: Google [Bot] and 196 guests
