Need help to trace Bluetooth Packets
Hi Espressif Team or others,
We have started to look Bluetooth Stack and Application as per our project requirements and started to evaluate it. So, Do you have any idea like is there any tool available to sniff Bluetooth Packets for debugging purpose?
We have tried to look couple of devices but didn't find appropriate as per our requirement. So, Please suggest us to use appropriate Bluetooth Sniffer Tool including software and hardware for our purpose.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Re: Need help to trace Bluetooth Packets
Hi WiFive, Angus, Developer,
Do you have any idea regarding Bluetooth Sniffer tool with software support?
So that it will be good for us to debug issue or capture required traces for Bluetooth analysis.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi Espressif System Developers,
Anyone has any idea regarding this? because we are blocked at some point while doing for bluetooth application. It will be good and appreciated if someone will give feedback for same.
We have looked some reference tools and software for that but that didn't match our requirement for same.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Module like this one:
https://www.adafruit.com/product/2269
Tutorial:
https://learn.adafruit.com/introducing- ... le-sniffer
Tutorial:
Thanks for providing response for same.chegewara wrote: ↑Wed Dec 05, 2018 7:22 amModule like this one:
Tutorial:
Do you have any other tool apart from above mentioned? send me those details as well if you have. Also we need only Bluetooth Sniffer like WiFi Tracer to check and debug packets of Bluetooth communication.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Yeah. Thanks. That we have seen earlier. Would you please suggest us which one is more preferable to use as per our requirement?
Regards,
Ritesh Prajapati
Ritesh Prajapati
Thats the question to real bluetooth specialist (i am more amateur).
First one is cheap nRF ble chip which in theory should be able to sniff packets and can be used with free wireshark application.
The other is hell a lot expensive hardware ($13k), highly specialized, device to sniff all kind of data packets (wifi, bt,pickonet, audio etc). You have to ask yourself, do you need it and is your project worth to buy it? Best strategy would be to try with cheap one and if its not working then maybe, just maybe, think about that expensive. But its just my opinion.
Ok. Fine. Thanks for feedback regarding same. will let you know if need any help regarding Bluetooth as well. Would you please provide your contact details like skype ID and email address? so that can reach to you as quickly as possible for any urgency w.r.t. Bluetooth.chegewara wrote: ↑Wed Dec 05, 2018 10:12 amThats the question to real bluetooth specialist (i am more amateur).
Regards,
Ritesh Prajapati
Ritesh Prajapati
That's the sniffer and software I used to reverse engineer the Bt BLE communications on my project when I first started. Worked great for me and was easy to use based on the info in those links.Ritesh wrote: ↑Wed Dec 05, 2018 8:05 amThanks for providing response for same.chegewara wrote: ↑Wed Dec 05, 2018 7:22 amModule like this one:
Tutorial:
John A
Users browsing this forum: ESP_Roland, Google [Bot] and 111 guests
