Swift mobile app does not work
nader_ahmed
Postby nader_ahmed » Tue Dec 11, 2018 8:22 pm
I downloaded the SWIFT iOS mobile app but it does not work:
https://github.com/espressif/esp-idf-provisioning-ios
Did I download the correct version?
I have uploaded my version here:
https://github.com/naderahmed/esp32_swift
Can someone help me?
ESP_anuj
Re: Swift mobile app does not work
Postby ESP_anuj » Thu Dec 13, 2018 7:48 am
Hi
I just verified that it works. Maybe an issue with the configuration in menuconfig?
Can you please check -
- You are using WiFi Sec 1 Debug build in iOS
- In your IDF, you are using examples/provisioning/softap_prov
- In the example, you have set Example Configuration->Use Security Version 1
If you haven't made changes to the PoP, the default abcd1234 should be set on both the device as well as the smartphone app
PS - I have also replied on the GitHub thread - https://github.com/espressif/esp-idf/issues/2827
cesarnascimento
Postby cesarnascimento » Thu Dec 13, 2018 6:18 pm
We are using the smartconfig example code (/esp/esp-idf/examples/wifi/smart_config).
Cesar
Users browsing this forum: No registered users and 24 guests
