Hi all,
I was trying to combine two ESP-IDF examples: one is ADC that I use an external potentiometer to adjust the ADC reading, and the other is to update the blinking LED PWM frequency.
Hardware setup:
Pot: 3.3V, GND, and pin GPIO34
GPIO 18 -> LED -> 330 Ohm resistor -> GND
Here is my code:
When I turn the pot knob down such that the mapped frequency is less than 10Hz, I get "ledc: div param err, div_param=2500000." When I increase the ADC reading voltage such that the mapped frequency is above 10 Hz, the problem is gone.
What does this error mean? And how do it fix it?
I tried with giving a fixed ledc_timer.freq_hz to the ledc_set_freq() function, but the problem remains the same.
I also tried turning of vTaskDelay(), the problem remains the same.
Thank you for any suggestions and comments
Error using ledc_set_freq() function
Re: Error using ledc_set_freq() function
i had also problems with this function and you have to set the freq value carefully. If you set the value too low, the timer would overflow and this causes an function error or even SW Reset with complete CPU restart. Switch on the serial monitor to get feedback from the ledc driver.
This is my code:
This is my code:
if (Pendel_freq > 20)
{ // AVOID Parameter error caused by Pendel_freq !!!!!!
ledc_set_freq(ledc_channel.speed_mode, ledc_timer.timer_num,Pendel_freq);
else
if (Pendel_freq == 0)
// ledcWrite(Pul_out_cha,0);
ledc_stop(ledc_channel.speed_mode, ledc_channel.channel, 0);
else
ledc_set_duty(ledc_channel.speed_mode, ledc_channel.channel, 200);
ledc_update_duty(ledc_channel.speed_mode, ledc_channel.channel);
Users browsing this forum: StuartsProjects and 103 guests
