Setting up Visual Studio Code for ESP32 IDF
Re: Setting up Visual Studio Code for ESP32 IDF
Any thoughts on doing this with VS Community instead of VS Code?
The links in the guide are dead.
https://docs.espressif.com/projects/esp ... toolchain
How to get ESP-IDF
How to get ESP-IDF
Updated links to newest version (as of right now)
I made a VsCode project template/tutorial that include debug settings and operation buttons:
Menuconfig, Build, Flash, Monitor, Clean.
https://github.com/botofancalin/Esp32_debug_template
The project name is named using project folder name.
So if you need your own project, just rename the folder from "Esp32_debug_template" to your project name
Menuconfig and other operations run on VsCode terminal window.
@Deouss
Will be useful if you add build buttons and debug features to your tutorial.
Feel free to get those settings from my project.
@Deouss
- menuconfig.jpg (253.23 KiB) Viewed 8474 times
Hey CalinB!
Thanks for your input! I will definitely look at those tools because VSC needs some extension that would make things easier for esp development. Intellisense should be more filtered just to the project objects.
Thanks again!
Thanks again!
Giving up on Eclipse cmake combo for now.
Cannot resolve "Unresolved inclusion". Tried funny ways to somehow get some of the errors, but not for production.
Will give VSC a try over the weekend. Have been struggling on Eclipse Cmake for almost a week now.
Need to settle on a environment and kick off the project!
Paul
Paul
Did you ever figure out how to use VSC as an IDE for ESP32 IDF? If so, do you have a pointer to how to set it up?
Thanks.
Steve
Thanks.
Steve
Users browsing this forum: No registered users and 233 guests
