Hi guys,
I'm trying to run two gpio inbuilt interrupts example. But both my interrupts take on the main code as soon as i connect a jumper to the pin.
I guess there is a floating pin issue in which case i'm taking a 4.7 k Ohm Resistor and a .1 uF capacitor also i've changed the gpio pins to 34 35 and still the same thing is happening . Please help.
Two GPIO Interrupts running continuosly .
Re: Two GPIO Interrupts running continuosly .
Can you post your code?
#define GPIO_INPUT_IO_0 4
#define GPIO_INPUT_IO_1 5
void gpio_initialise(gpio_config_t io,void *gpio_isr_handler,char pin_no)
gpio_config(&io);
if(gpio_isr_handler!=NULL)
gpio_install_isr_service(0);
gpio_isr_handler_add(temp,gpio_isr_handler,(void*)pin_no);
#define GPIO_OUTPUT_IO_0 18
static void IRAM_ATTR gpio_isr_handler1(TaskHandle_t Handle)
// int pin_no=(int)Handle;
// if(pin_no==GPIO_INPUT_IO_0)
level=0;
// else
// level=1;
static void IRAM_ATTR gpio_isr_handler2(TaskHandle_t Handle)
level=1;
// else
void app_main()
gpio_config_t io_conf0,io_conf1,io_conf2;
io_conf0.intr_type=GPIO_PIN_INTR_NEGEDGE;
io_conf0.mode = GPIO_MODE_INPUT;
io_conf0.pin_bit_mask = (1ULL<<GPIO_INPUT_IO_0);
io_conf0.pull_down_en = 1;
gpio_initialise(io_conf0,gpio_isr_handler1,GPIO_INPUT_IO_0);
io_conf1.intr_type=GPIO_PIN_INTR_POSEDGE;
io_conf1.mode = GPIO_MODE_INPUT;
io_conf1.pin_bit_mask = (1ULL<<GPIO_INPUT_IO_1);
io_conf1.pull_down_en = 1;
gpio_initialise(io_conf1,gpio_isr_handler2,GPIO_INPUT_IO_1);
gpio_set_direction(GPIO_OUTPUT_IO_0,GPIO_MODE_OUTPUT);
while(1)
gpio_high(GPIO_OUTPUT_IO_0);
vTaskDelay(1000/portTICK_PERIOD_MS);
gpio_low(GPIO_OUTPUT_IO_0);
printf("Level :%d\n",level);
// prev_state=level;
vTaskDelay(20/portTICK_PERIOD_MS);
// if(level==prev_state)
gpio_set_level(GPIO_OUTPUT_IO_0,level);
fflush(stdout);
The code works fine up and untill i change the interrupt pins to 34 and 35
gpio_config(&io);
level=0;
// else
// level=1;
level=1;
// else
void app_main()
while(1)
fflush(stdout);
Users browsing this forum: Bing [Bot], Majestic-12 [Bot], MicroController and 135 guests
