Cannot connect to NTP server with fixed IP
lesept
Postby lesept » Mon May 13, 2019 1:31 pm
Hi
I usually use the sketch from here https://lastminuteengineers.com/esp32-n ... -tutorial/ to get the time via NTP. But when I use a fixed IP for my ESP32, the connexion to the NTP server doesn't work anymore.
Here is the modified sketch: the fixed IP part works in any other conditions.
#include <WiFi.h>
#include "time.h"
const char* ssid       = "YOUR_SSID";
const char* password   = "YOUR_PASS";
// **** These lines added :
//Static IP address configuration
IPAddress staticIP(192, 168, 0, 51); //ESP32 static ip
IPAddress gateway(192, 168, 0, 254); //IP Address of WiFi Router
IPAddress subnet(255, 255, 255, 0);  //Subnet mask
IPAddress dns(192, 168, 0, 254);     //DNS
// *** up to here
const char* ntpServer = "pool.ntp.org";
const long  gmtOffset_sec = 3600;
const int   daylightOffset_sec = 3600;
void printLocalTime()
  struct tm timeinfo;
  if (!getLocalTime(&timeinfo)) {
    Serial.println("Failed to obtain time");
    return;
  Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
void setup()
  Serial.begin(115200);
  //connect to WiFi
  Serial.printf("Connecting to %s ", ssid);
  WiFi.mode(WIFI_OFF);
  WiFi.config(staticIP, dns, gateway, subnet);
  WiFi.mode(WIFI_STA); //WiFi mode station (connect to wifi router only)
  delay(100);
// *** up to here
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println(" CONNECTED");
  Serial.print("WiFi connected - IP address: ");
  //init and get the time
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  printLocalTime();
  //disconnect WiFi as it's no longer needed
  WiFi.disconnect(true);
void loop()
  delay(1000);
  printLocalTime();
I get :
Connecting to ***.. CONNECTED
WiFi connected - IP address: 192.168.0.51
What is wrong? Thanks for your help.
martinayotte
Re: Cannot connect to NTP server with fixed IP
Postby martinayotte » Mon May 13, 2019 8:16 pm
Is this DNS really able to resolve it ?
Is this address of your router ?
Doesn't have external DNS enabled ?
Did you tried using 8.8.8.8 as the DNS ?
boarchuz
Postby boarchuz » Mon May 13, 2019 9:57 pm
Reorder the parameters in config:
bool WiFiSTAClass::config(IPAddress local_ip, IPAddress gateway, IPAddress subnet, IPAddress dns1, IPAddress dns2)
lesept
Postby lesept » Tue May 14, 2019 8:09 am
@martinayotte : Actually, I don't know. How can I find this information?
@boarchuz : I'll try to change the order. Thanks
martinayotte
Postby martinayotte » Tue May 14, 2019 3:15 pm
If on your PC, the DNS is the same 192.168.0.254, then try to ping "pool.ntp.org" from the PC.
If it is not working there too, then your router is misconfigured.
As I said, try using 8.8.8.8 as DNS, it should work ...
lesept
Postby lesept » Thu May 16, 2019 12:43 pm
Changed the order of the parameters in the config. Changed the DNS to 8.8.8.8.
It works now, thanks a lot!
SlemiELK
Postby SlemiELK » Mon Jul 01, 2019 4:57 pm
Hi!
I also had problems with this. The following code solved it:
IPAddress ip(*,*,*,*);
IPAddress gateway(*,*,*,*,);
IPAddress subnet(*,*,*,*);
IPAddress dns1(*,*,*,*);
IPAddress dns2(*,*,*,*);
WiFi.config(ip, gateway, subnet, dns1, dns2); //This is important! Include dns1 and dns2 when configuring!
enter your configuration where there are *
Regards!
Viafx24
Postby Viafx24 » Sat Jul 09, 2022 10:50 pm
Agree with the last comment but i did not need to add two dns (dns1 and dns2). Only one dns. (Dns appears to be a thing needed to allow the esp to go on internet and looks to be often the same than the gateway; at least in my case it is the same i.e 192.168.1.1). THUS, the MAIN POINT was to put dns at the end of the parameters of Wifi.config. It looks like the order matters. I dont know why but when dns was placed just after staticIP, it failed to work for me. Cheers.
Working code for me:
IPAddress local_IP(192, 168, 1, 24);
IPAddress gateway(192, 168, 1, 1);
IPAddress dns(192, 168, 1, 1); //needed to go on internet
WiFi.config(staticIP,  gateway, subnet, dns);
Users browsing this forum: Majestic-12 [Bot] and 25 guests
