Hello, everyone,
I have an ESP32 (Himalaya Matrix Core: https://eckstein-shop.de/HIMALAYA-Matri ... -DEV-Board). I would like to use the SPH0645 (https://learn.adafruit.com/adafruit-i2s ... t/overview) via I2S to measure the volume in the environment.
Unfortunately I'm totally lost, because the documentation is not really meaningful. I would like to do the exact same thing as described here with the Feather M0: https://learn.adafruit.com/adafruit-i2s ... g-and-test
Were do I need to start? Where are the I2S pins on my board? How to use the library in the example in my platform.io environment? Can I use the library with an ESP32?
You'll notice. I'm totally lost right now.
Any help would be really great!
Many thanks in advance!
Using the ESP32 with SPH0645 Micophone (I2S)
Re: Using the ESP32 with SPH0645 Micophone (I2S)
Did you made some progress? I'm totally lost too.
I'm using the Adafruit Feather Huzzah Esp32 with the I2S SPH0645 microphone, but I can't make it work.
Any ideas? Someone can give me a hand?
Maybe a little late, but since this thread showed up in search, the key information is in:
https://docs.espressif.com/projects/esp ... s/i2s.html
with important notes on the mic in the comments here:
https://hackaday.io/project/162059-stre ... microphone
also related:
https://www.esp32.com/viewtopic.php?f=13&t=1756
The resulting sketch is something like:
also related:
#include "driver/i2s.h"
#include "soc/i2s_reg.h"
#define BUFLEN 256
static const i2s_port_t i2s_num = I2S_NUM_0; // i2s port number
static const i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX),
.sample_rate = 22050,
.bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = 0, // default interrupt priority
.dma_buf_count = 8,
.dma_buf_len = 64,
.use_apll = false
static const i2s_pin_config_t pin_config = {
.bck_io_num = 26,
.ws_io_num = 25,
.data_out_num = I2S_PIN_NO_CHANGE,
.data_in_num = 22
void setup() {
pinMode(22, INPUT);
i2s_driver_install(i2s_num, &i2s_config, 0, NULL); //install and start i2s driver
REG_SET_BIT( I2S_TIMING_REG(i2s_num),BIT(9)); /* #include "soc/i2s_reg.h" I2S_NUM -> 0 or 1*/
REG_SET_BIT( I2S_CONF_REG(i2s_num), I2S_RX_MSB_SHIFT);
i2s_set_pin(i2s_num, &pin_config);
int32_t audio_buf[BUFLEN];
void loop() {
int bytes_read = i2s_read_bytes(i2s_num, audio_buf, sizeof(audio_buf), 0);
// have fun with your data
Users browsing this forum: Google [Bot] and 135 guests
