after code compiles and CONNECTING is displayed I have to press the D32's reset button once a second in a crapshoot to get it to connect or else I get "A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header"
This process will make development a huge headache, what am I missing ?
LOLIN D32 - Trouble uploading skethc via arduino
Re: LOLIN D32 - Trouble uploading skethc via arduino
I have similar connection problems. I use the ESPTOOL with Lolin D32 boards to install the MicroPython firmware binary.
Here is how I fixed the connection problem:
I added an external 1 uF capacitor between the RESET and GND pins. This change is discussed on the MicroPython forum:
https://forum.micropython.org/viewtopic ... 7&start=20
Look for the posts that contain images of oscilloscope captures.
Maybe this will work for you?
I have a new Wemos Lolin D32 board and also got errors when flashing. I solved the issue by reducing the baud rate for flashing to 115200.
I can flash the older Lolin 32 board with 921600 baud with exact the same hardware environment (USB port, cable).
Don't forget to double-check:
1/ The USB cable, change it with another.
2/ The Port and board configuration.
3/ Remove any device connected to the ESP32 during the flashing.
I don't think that the reset is an issue. but the you can try also reducing the baud rate as suggested before.
Hope it helps.
Hope it helps.
Try grounding the GPIO 0 pin. Take it out when you're done. Fun...
Users browsing this forum: No registered users and 147 guests
